Electronic F & 2F Distributors
Marshal I read the thread and unless I am missing something you said you were going to the parts store to get some part numbers of 12v coils with no risitor. I never saw where you gave us the part numbers that fit the stock coil bracket.
I finally looked at my Distributor I got a couple months ago and after reading above I have discovered I too have a spring loaded rotor. Marshall do you have any rotors that are not spring loaded? If not what rotor can I get to replace it? I do not want extra parts that can fail on the trail either. I would gladly send you back the spring loaded on if I can find a standard rotor that will work.
Rotor for a 76-77 distributor will work.
I've yet to find one that fits the stock coil bracket. Why Toyota made it larger is beyond me. For the shop installs I've just been wrapping electrical tape around them until they fit. You really can't notice unless you look really hard.
so what coils are you buying then? you didnt answer that....
Bought mine at Oreilly. I'll try to find a part # but it fits the stock bracket just fine...
Dizzy in stock?
I plan on buying a dizzy on the 28th. Do you have them in stock? I dont care if its big or small cap.
Maybe someone with a small cap wants to sell me theirs?
Thanks Marshall
:cheers:
I sent money a few weeks ago via paypal and have not received a package yet.
Update?
It took 3 months to get mine. It might be a little while for yours.
Maybe I am overthinking this whole thing but I am preparing to install my distributor and trying to figure out which coil to use. I've read through this thread several times and can't seem to grasp this. My 9/75 40 has the coil with attached resistor and igniter assembly. The coil I have (assuming original) is Nippon Denzo and has "with external resistor" printed on the body. I know I need to disconnect the igniter but can I just disconnect the resistor and use this coil??? I went to a local auto parts store and the choices seemed to be non- resisted coils. I was under the impression from reading this that I needed to find an "internal resistor" coil. What the heck do I need here? TIA.
Still waiting for that box in the mail>>>>
hello< mcfly????
Marshall, did you ever get big caps in to replace the small caps we got when they shipped you the wrong stuff? I am interested in one...
To answer the coil question, you can use about any coil you want.
Nearly all coils operate on 6V, it is just the way they are.
The stock setup uses a 12V ignition switched power feed to the resistor. The resisitor drops the power to 6V before it enters the + side of the coil. This aids in coil life and points life.
New Toyota coils are internally resisted now. An aftermarket one with internal resistor will be the same. They reduce the input voltage to 6V inside of themselves.
Marshall directs you to attach one wire to the + side of the coil and the other to the - side. The + side needs 12V to go to the electronic module of the distributor. That is all this wire needs, ignition switched 12V power, it has nothing to do with the coil. The negative wire is what triggers the coil to fire into the plug wires.
You can retain your stock coils and resistors by attaching the + side wire of the distributor to the input side of the resistor. That is the side that attaches to the wiring harness. the other end of the resistor will have a short wire over to the coil. The - side wire attaches to the - side of the coil. The ignitor can be disconnected entirely and removed if wanted. The ignitor was part of the original electronic iginition system, and has no bearing on the function of the coil or the new distributor triggering module within the distributor itself.
I added the Unilite system to my points style Mallory distributor years ago. This is how it is hooked up, two wires, + and - and it needed 12V. Has worked great for years hooked up to the input of the resistor.
A question to Marshall and the group, what plug wires are you using or recommending?
What year spread OEM wires fit this cap the best, or does that matter. For example the plug wires for an FJ-60 are really nice, do they fit the early smaller caps properly, or do you need wires from the early or mid 1970's for a proper fit.
To answer the coil question, you can use about any coil you want. Nearly all coils operate on 6V, it is just the way they are. The stock setup uses a 12V ignition switched power feed to the resistor. The resisitor drops the power to 6V before it enters the + side of the coil. This aids in coil life and points life. New Toyota coils are internally resisted now. An aftermarket one with internal resistor will be the same. They reduce the input voltage to 6V inside of themselves. Marshall directs you to attach one wire to the + side of the coil and the other to the - side. The + side needs 12V to go to the electronic module of the distributor. That is all this wire needs, ignition switched 12V power, it has nothing to do with the coil. The negative wire is what triggers the coil to fire into the plug wires. You can retain your stock coils and resistors by attaching the + side wire of the distributor to the input side of the resistor. That is the side that attaches to the wiring harness. the other end of the resistor will have a short wire over to the coil. The - side wire attaches to the - side of the coil. The ignitor can be disconnected entirely and removed if wanted. The ignitor was part of the original electronic iginition system, and has no bearing on the function of the coil or the new distributor triggering module within the distributor itself. I added the Unilite system to my points style Mallory distributor years ago. This is how it is hooked up, two wires, + and - and it needed 12V. Has worked great for years hooked up to the input of the resistor.
Thanks for the clarification! Appreciate it.
Yippee
marshall, i still want the big cap one instead of the small cap one you sent me on the last shipment you got.
