These are an excellent idea for anyone looking to retain radius arms. Other than ground clearance loss, they are only beneficial for suspension geometry, caster, bushing life, etc. Product looks nice too
Ordered...thank you !!
You would need to correct 2" of caster.@eimkeith how would your RAM kit work with 4” lift springs in the front? Any idea on caster numbers?
I’ll be adding Slinky front control arms, which correct caster for their 75mm lift. With these drop brackets, how am I affecting castor? Adding additional castor?
That’s a good question. Before I ordered your brackets, I gave them a call. Mill Creek Overland said the Slinky arms do not change the wheel base at all. So, no forward movement.Hold on - do those Slinky arms move the axle forward at all?
Your 1.75” lift is 44mm. The @eimkeith RAM is designed for a 50mm lift, so I’d assume your close to the castor correction you’ll need. Sounds just right to me.So, am I crazy, is this overkill for a 1.75" lift running 295/75r16 (maybe 315s) (I can't go much bigger since I'm still using the factory spare mount, Joey says 34.25 is max)
Yes they are longer than stock radius arms so they will center the axle in the wheel arch and straighten out the coil. So if using them in combination with your drop bracket it may move the the axle enough that the bumpstop doesn't align with the axle pad very well. It would also probably mean that the forward part of the wheel well would need to be cut out. I had to cut 2" off my bumper wing and cut out most of the wheel well under the battery tray for my 37's to clear after moving my axle 1.25" forward.Hold on - do those Slinky arms move the axle forward at all?
Say WHAT ?@eimkeith what are your thoughts on 2” drop brackets for the rear control arms (both uppers and lowers)? It would stop the roll steer and sidehill jacking effects that lift the front tires on 80’s with 4” lifts.
Say WHAT ?
How would you accomplish this ?
I'm not seeing the advantage.![]()
80/105 Land Cruiser Rear Long Arm Kit – Corrected Suspension Geometry | Rampt Customs | Rampt Customs
80/105 Series Land Cruiser Rear Long Arm KitA complete rear geometry solution — relocated upper and lower mounts, not just longer arms.The 80 and 105 Series left the factory with genuinely good rear suspension geometry. This kit takes it to the next level: longer arms combined with relocated...www.ramptcustoms.com.au
I got the idea from the upper control arm drop brackets that Rampt sells with their long arm kit. I don’t see how the long lowers make sense with the super short uppers, but if you are willing to accept the ground clearance loss at the factory lower mounts, you could fab new brackets that are 2” lower with generous wedge skids to grind them on the rocks. If you flatten the lower arms the suspension won’t jack and lift the truck anymore (like factory ride height doesn’t).
Drop brackets get a lot of hate but if the factory suspension works they just correct back to that handling plus lift.
-Bucket
I prefer to run a lower lift (under 3") and bigger tires This work really well for me.
A lot of heavily modified vehicles were struggling with this obstacle, with a 2" lift (netting 23/4" lift) and 39s I walked right one shot no drama.
