Can the advance on a DUI be adjusted for pressure, some other dist. have an allen adjustment inside.
Thanks.
Thanks.
I did some searching and unported vacuum sounds like it would mess up the whole concept of vacuum advance, unported has high vacuum at idle. But.......it's hard to argue with " helped driveability profoundly".
The vac advance is adjusted based on the cam, compression, altitude, etc.
FWIW, a vacuum leak will have little affect on the production of ported vacuum. Ported vac is a result of the venturi effect right at the edge of the throttle blade in the throat of the carb. That is why it is different from manifold vac, it's a different source.I understand the basics regarding the dizzy, I'm just curious why he'd have to change the vacuum advance setting? (I'm assuming that he's running a basically stock 2F with similar components as I am.) Outside of running a non-stock cam, I can assume he may have a vacuum leak.
Did a google search and found this "TIMING AND VACUUM ADVANCE 101", nice article on vacuum advance. It really brings home the concept of lean/rich mixtures and when the advance needs to be applied. I can see that the ported vacuum should be used with emission stuff but if you are desmogged like me then unported(direct from manifold) is something to try ASAP. This could help engine temps, fuel economy, valve life.
This could end up being one of those best cheap mods. I think most folks just hook the vacuum line to the carb and don't pay alot of attention to what the port is and what is required...
FWIW, I'm pretty much satisfied with the mechanical advance that the DUI gives, but I've found that the mechanism would stick from time to time. I know you're not supposed to lube the weights, but some WD40 solved my problem of stuck weights.
The vacuum advance that came with mine allowed so much advance that it's plain to see they subscribe to the "advance it until it pings" mentality. The problem here is that the 2F, with it's super-low compression ratio, isn't going to make much noise when you've pushed avance over the line. It will, however, wear out much quicker.
okay, I guess. I eventually went with an adjustable advance mechanism and have been pretty pleased.As mentioned, there are ways to fab up a travel limiter for the advance unit to reduce vacuum advance.
After the FJ40Jim post above I have a question ( I hope this isn't off topic) - Since everybody has always been trying to find a way to get ported vacuum from their older vacuum retard era carbs/distributors. Why couldn't an HEI or Non-USA OEM distributor be curved to work with manifold vacuum? I realize that manifold vacuum starts at idle and ported vacuum comes in at off-idle but don't both disappear pretty quickly as the throttle opens?
The point of vacuum advance is not to have a bunch of advance at idle, then have it disapear @ WOT.
The point is to have no vacuum advance at idle, then bring in advance imediately on light throttle, then have it disappear at WOT.
It has little to do with adding fuel. The amount of advance needed is determined by two basic factors: RPM and cylinder pressure. The flame burns at a relatively constant rate, so as engine speed increase, the flame has to be lit sooner to allow time for the flame to burn across the chamber. Mechanical advance takes care of that.The first thing I see is if you go WOT then you want the engine to rev but your vacuum goes away temporally, you would think this would be a good time to advance the timing but according to the doc "TIMING AND VACUUM ADVANCE 101" it's OK to loose the advance because you just dumped in a bunch of fuel.
