- Thread starter
- #21
Thanks @Steamer ordered the relay
Like This?The only difference from the diagram that Steamer showed is that I installed the relay on the pink wire going directly to EFI not where shown on diagram since the ignition hot (on diagram) could still send a dirty signal to the EFI.
I edited the diagram (moved the relay) in post #15 to reflect your good points. Does your relay also feed the ignition or does it soley feed the Sniper pink wire? Maybe we need two relays? Hmmm.The only difference from the diagram that Steamer showed is that I installed the relay on the pink wire going directly to EFI not where shown on diagram since the ignition hot (on diagram) could still send a dirty signal to the EFI.
I run two relays. One relay for my sniper that is included in the main harness and one relay for my DUI. My sniper gets an ignition signal from an unused smog computer wire and my DUI gets its signal from the coil positive factory wire (black and yellow). Coolerman builds a harness for the DUI that I used. It’s super slick, I did extend some of the wires so if I had to do it again I’d ask him to just leave the wires long and I’ll trim and terminate to fit.I edited the diagram (moved the relay) in post #15 to reflect your good points. Does your relay also feed the ignition or does it soley feed the Sniper pink wire? Maybe we need two relays? Hmmm.
