I'm not sure what you guys are talking about. What "divet."
the shackle mount itself has an indentation in the shape of the spring eye (red arrows) from the spring eye banging into it
maybe it's not as bad as on my truck
Spring over lift.
Not sure what the best solution is to that drive train angleSurely you're not the 1st guy to put an NV4500 behind a 2f?
A body lift would allow you to tilt the drive train up and could help the situation, but not an elegant solution. And body lifts have their own set of challenges.
To avoid vibration the pinion and drive train center-lines need to be fairly close to parallel. Looks like they are not at the moment.
The rear shackle/spring situation needs to corrected regardless of the drive train issue. That has to ride like a rock!
A double cardan (CV) joint on the drive shaft isn't going to help unless you rotate the pinion angle to be parallel to the drive shaft angle.
Why a 4500 instead of a H-55 . i doubt the 2F has the guts to push that deep of overdrive. You need to reconsider the placement of the transmission or the rocks will do it for you
Click here and read the info on the tech info section
So your engine can't fit in front of the firewall without hitting anymore? I'm not really familar with the stock setups, but it seems to me that it originally fit without hitting the firewall and you need to move it back so it will again.![]()
That was the first thing we looked at. There is only a 1/2" between the fan shrouded and the engine. So, no space to move engine forward.....
Now we are well beyond the point of return.
I feel slightly retarded not seeing the ridiculous angle the engine has. I'm thinking new front engine mounts that lower the engine about 1 1/2" would reduce the angle tremendously. I have that much space available in the fan shroud to play with. Is this possible?
Are you using stock engine mounts? If you are they must be severely stressed and contorted.
