- Thread starter
- #101
quick temp awning rack..
means deployable shade!
know this, this is really-truly temporary
NOT to be confused with the much more common temporary-permanent as quick jobs can be[come].![]()
That is so funny and true.
As for the welds, I am not trying to be critical but some of those look like you did not get good penetration. The spatter will just be there with flux core. I started on one of those and a grinder can take care of those if you want to clean them up a bit. One trick a fabricator taught me was to turn your work vertically when you can and gravity will help your bead puddle and result in better looking welds. Get a helmet as two hands makes a huge difference. As you alluded to, a shorter heavier extension cord may help a bit.
The scary thing here is that looks like galvanized steel. Be careful about breathing in that nasty stuff, even outside make sure those fumes drift away from your face. Consider grinding off that coating before welding. Another thing is that some people use brake cleaner to prep surfaces; don’t be one. I think most new stuff is non-chlorinated but the arc can cause a very nasty chemical reaction and make toxic fumes. Point is be careful of your solvent choices. Maybe you know all this but I am not trying to come off as an expert just sharing things I have learned over the years as a hobbiest
One last thought on the flip flops. One day you will get a nice bounce of spatter on your foot that will burrow into your flesh. Good thing is it won’t bleed much as it will self cauterize.
Find some scrap steel and keep practicing. Once you start welding the projects and things you can do are endless and fun.
I've seen similar on a 4R thread, but I didn't want to drill the crossbars. Fear of clamping too strongly and collapsing the hollow bar w/o a sleeve inside. Plus are they just plastic or is it an aluminum tube covered in plastic? I dunno....I commend you for posting pictures of those welds. Clever bracket idea though. Have you considered drilling through the factory rails and bolting your "L" bracket through the factory cross rails?
@DRANGED so did you just replace some ripped cv boots ? How was that job ?
HAHA, coincidentally that's the first place I went (mentioned those stops in this post)... I emailed them even, but another comment suggested that while they're taller, their progressive/soft and at full stuff they probably wouldn't be at the most compressed, therefore not fully functional ...You could get the wheelers extended length bump stops too....
Wheeler's Front SuperBump Bumpstop Set for 2005+ Tacoma, 2003+ 4Runner, 2007+ FJ Cruiser, 2007+ Tundra (01SUPERBUMPKIT)
