A profile bender would work too. Any railing shop should have a way to do it. It's the tool they would use to bend the top cap of a spiral or otherwise curved stair railing.
Thanks for all this great info! I am down in Nicaragua and I am in the process of having a frame and soft top built. My body is a 1965 that was originally a soft top. I swapped out the everything with a 1977, but kept the body. I am using the post and top pieces from the hard top 77, what do you recommend for the front piece over the windshield? I cut that off the hard top as well, should I use that or just create a c channel? Also, anyone have details of the soft top connections. I am getting that custom made and would love some original picks so I can try and duplicate. Most concerned on giving detail fotos to the guy sewing the topHere are some measurements in inches for the front bow.
What are the rivets and spot welds for?
I ask because don't recall seeing that in the diy so am curious if this is for a different style top?
Someone posted in another thread a couple of years ago that one of the vendors, CCOT I think, was offering a repop channel. Probably a Real Steel product. Try a search query for “channel”.
I wanted to resurect one of the missing @Pin_Head pictures that illustrates the measurements of the middle bow and the spreader side bows.
I was happy when I saw @78fj40mg post this pic in another thread.
Figured it would be helpful to post it here with the other measurements and the diy steps.
Thank you Brian!Bows should all be the same height. I wouldnt do anything with the footman loops until you put the top on. The tie downs will dictate where the footman loops will go. I have had a least 5 factory softtops over the years, and none of the oem replica tops lined up with the factory footman loops.( they were close but not exact)
Eggzackery!Bows should all be the same height. I wouldnt do anything with the footman loops until you put the top on. The tie downs will dictate where the footman loops will go. I have had a least 5 factory softtops over the years, and none of the oem replica tops lined up with the factory footman loops.( they were close but not exact)
Bumping an old thread. Has anyone made the rear bow needed for the ambulance doors vs the rear zip hatch? Planning on building a set of bows and doing the rear soft ambulance doors and was seeing if anyone has done them before.
That is actually a good price with the doors. Wish I had seen this when I was as buying mine separately to save moneyHit the easy button.
FJ40 Soft Top Kit with frame | eBay
In the interior it is patted with Hi Loft®: 100% polyester knitted textile, which gives a stronger base fabric of unusual softness. It has a 1.1mm gauge. Also included is complete stainless steel hardware set.www.ebay.com
okRight off no US imported 40 series was set up with barn doors and spare on the left. If installing on cruiser with ambulance doors would have to be sure those rear door combined are wider than the hard ambulance doors. Pictures should the doors against the back not flush like the hard ambulance doors. Not going to be a just bolt these new doors on and your set if you have a US version 40 series. If the ambulance doors were to reversed would make it a easy conversion on US models with barn doors.
Someone must have been bow for the rear ambulance doors because I bought one of mud last summer. Going to need some straightening but better than starting from scratch. Not making bow because I already have factory bows. Difference from kit above mine all are all made for soft doors. Those the B pillar is straight.
