Highly recommend only OEM for everything.SEIZED… CAM… BOLTS!!!
My tire guy referred to this current situation as “Common Toyota Manufacturing Defect”…
Blasphemy!!
New LCAs imminent prior to lift install.
Stand by.
Blasphemy!!
Stand by.
I thought someone may bring this up. But I’m with @04UZJ100 . If Toyota wants these bolts seized every ten years, so be it!SPC sells an upgraded cam bolt with a sleeve designed to prevent this. If I had to replace mine, those would be the replacement.
Cruiser Outfitters uses and stocks them, which speaks highly of the product in my book.
SPC Caster/Camber Adjustment Bolts
Searching the forum last night I couldn't find any mentions on these SPC adjustment bolts so please excuse the duplicate if I missed it. Looking to see if anyone has experience with these? I just added the Tough Dog lift with the OEM spacers up front and trying to avoid the UCA's if possible. I...forum.ih8mud.com
"This is an OE replacement cam with a corrosion resistant coating superior to the OE bolt. This kit will not give you much over what the OE bolt will get, but will not freeze into the bushing like the OE bolt."
275/70r18 K02 E-rated tires are on, still with the stock height springs- until I get new LCAs, along with installing the Old Man Emu lift. They look and handle great. No noticeable rubbing.
The truck drives smooth and handles potholes well at 38psi. I always love me some K02 tires.
These are my first E-rated set, I ran C-rated on my GX470 and 5th Gen 4Runner. These run a little more firm, but they're still plenty smooth and quiet on the highway back from the tire shop. Very happy I chose them again. I've done well in various on road and off road conditions with K02s in the past. They are my "do all, be all tire." I'll certainly let it be known if I ever do experience poor performance with them- mud, standing water, ice can all cause issues for some folks running K02s, so it is possible- but hasn't happened to me yet running them in all of those scenarios on 2 other Yotas.
View attachment 3047779View attachment 3047780View attachment 3047781View attachment 3047783
Do not use SPC cam bolts. They’re cheaply machined and do not provide the necessary clamping force to keep the LCAs from moving around. Further, they’re machined with grease channels in them which appear “functional” but end up compromising the strength of the bolted connect.Let the fun begin...
New LCAs ordered and, apparently, 10 additional Toyota parts for the related bolts! I will use anti seize on this hardware when it goes into the new LCAs. I think the SPC cam bolts are a good way to go too, and time will tell if this was a smart or dumb route to go staying OEM.
Edit: I am questioning the clarity of the diagram on item 16 (Adjust Bolt Bolt - Toyota Part No. 90119-18006), do I need to order this bolt or not?
Cutting out the old cam bolts should be interesting. I know where to cut, question is what to cut them with for quickest and easiest removal?
OEM and antiseize is the only way I’d go.
The illusive 205 series...If you SAS you'll never have to worry about cam bolts seizing on you![]()
