Registry Diesel Transplanted 80 series Registry (5 Viewers)
I spent $4750 on the FJ80 in spring of 2007. Then sold my FJ62 for $3200 that following fall. The 1991 FJ80 was in excellent shape overall (no rust, clean interior, all original), but the engine had over 270,000 miles on it, which scared away most buyers.
I snatched it up knowing I wanted to do a diesel conversion at some point. I researched engine options, but decided on the Detroit Diesel used in GM trucks and the Humvee. If they're good enough for the U.S. Military, then they're good enough for me!
Within a couple of months I located two used motors that would work for my engine build. I purchased one, which came out of a 1988 V2500 Suburban for $300, which included the motor mounts, and wiring harness. The other was a 1991 out of a pickup for $275, and it cam with the GM turbo on the side. I ended up selling the newer motor for $500, but kept the turbo, and then I rebuilt the 1988 engine (J-type), which set me back about $2500 after having it machined and adding new internals, updated water pump, updated alternator, power steering pump, and AC compressor.
The A440F--used from 1988 to 1992, with the 3FE inline 6--is a better choice than using the A442F because the newer model is electronically controlled. The A440F still uses a detent (kick-down cable) to downshift during acceleration, and it doesn't need to talk to the engine to operate. We'll see how well it holds up the the vibration of the 6.2L diesel.
I spent $1300 dollars for the Marks Adapter, which allowed me to keep the A440F transmission. It's a bit pricey for what you get, but their the only show in town, and Advanced is the only distributor in the US.
Then I spent another $1000 to $1200 on materials and other parts to fabricate frame mounts, a new cross member for the transmission and other bits to make it all happen.
All told, I have about $7325 tied up in the project so far, but that doesn't include any modifications that I plan to do in the future, such as air induction and a suspension upgrade, as well as other mods planned for the future.
However, I am satisfied with the conversion overall. I like to increased performance and fuel economy over the older 3FE. My tired I6 was only generating about 120 HP when I pulled it out, and I now have about 215 HP and a little more torque to play with. I also like the simplicity of this engine, but I am constantly tinkering with it, trying to find out ways to make it a little better.
94 FZJ converted to HD-T Auto
1. Year and model of the original truck.
94FZJ80 US model from the west coast
2. Brief details of the Drivetrain that was swapped in.
Low mile 1HD-T with hydraulic A442 and non viscous transfer (ala FJ80)
3. What went really well with the swap?
It all went pretty smoothly. Its not my first diesel conversion though it was my first 80.
4. What was unexpectedly difficult with the swap?
Tach. Unless you have stock diesel gauges the tach is a problem with the HZ/HD engines. I have a diesel tach on the way to swap into the cluster.
5. Mods...aside from drivetrain, if any?
This 80 is well modded. OME 863 suspension, 4.88 gearing, Center lock mod, ARB front, 4xLabs rear, 315 tires and some cosmetics.
6. Driving impressions after the swap...including drivability in daily driving (if applicable), highway travel, and, of course, off pavement.
I love driving this thing. Its done about 3500 miles at this point. No off-road yet unfortunately. Currently driving it daily around town. The gearing combined with the tires make the gearing near stock.
7. Realistic fuel consumption after the swap...lol. :D
Its getting about 19MPG
8. Five star rating for overall difficulty of the swap: *=relatively easy, *****=don't even attempt it unless you have some real good friends who are really handy.
On the scale of conversions I have personally done its probably a 2*. The hydraulic trans makes it easier for sure. I modded the FZ wiring harness by basically removing everything that was not needed and then tied in the sensors for water and oil etc.
9. 2 to 3 pictures of your rig.
10. A link to your own build thread with all the juicy details and pictures.
Not much of a build thread but here is some info and photos
https://forum.ih8mud.com/diesel-tech-24-volts-systems/524862-my-recent-hdj-80-conversion.html
Ive had the 80 about 2 years and the intention was to build this to be my own travel rig for the trips I take around the Western US. As with past attempts to build something for myself I just cant afford to keep it. The conversion was completed in October 2011 and took about 6 weeks including the cosmetics (paint, wheels, etc) Its currently for sale and I will post a classified ad in the near future.
6.5 GM diesel swap
Well done :)
REALIZACJE |
1991 year Toyota Land Cruiser (FJ80) with new 6.5l GM naturally aspirated diesel and 5 speed manual tranny.
Id definitely source my motor from a NON-Land Cruiser importer.... these guys importing half cuts are ripping everyone off.... find an SR20 or Honda importer to do your half cut as a side job and it'll be way cheaper
Well what are you waiting for.. go get a price on a half cut HDJ81 from the Honda importer and report back so your post isn't entirely worthless!
I wish that was in the cards!
I have done an SR20 swap before... and I paid a premium for my motor, from a "nissan" specialist/importer... Once I got further into things I worked with another guy that imported subaru goodies and found that I could have gotten an SR20 much, much cheaper than for what I paid (and what I paid was basically the going rate at the time for general, nissan importers) ...
Someone that doesn't know the LC market would be a much better economic bet for obtaining a motor... of course the downside is that whoever they have shopping for them overseas might not be as fluent with Toyota Diesels as they are Nissan 4 bangers!
I have purchased engines from Sheldon before, and my advice is to use someone who knows their sh!#. With the miles on these engines, there's a solid chance you might be buying something with a rod knock or bad bearings. I would only trust a specialist on this one, otherwise you're just gambling
That would def. be the downside! And im sure diesels aren't like gasoline engines in japan.... its easy to find low km car motors... but im sure the diesels are a different story
Ok, what your rice racer import guy would find is that nobody in Japan is giving away Land Cruisers.
They get auctioned off to Australia, New Zealand, Russia, Canada etc and that demand drives the prices.
There are just about no half cuts for sale at any of the big cruiser parts shops in US and Canada..we can all draw our own conclusions, but hear this, it's not because they are all tired of making money.. or as you say "Ripping Everyone Off"
End Highjack... this is a Diesel transplant registry thread after all.
91 FJ-80 with 1HD-T swap
1. 1991 FJ80/1HD-T and a hydraulic A442F
2. Stock drivetrain with rear ARB
3. I didn't do the swap but the 80 was available with the 1HD-T so it fits well
4. California registration
5. A gianormous front bumper
6. Compared to my 1FZ it's louder, feels stronger
7. 19 mpg from Van Nuys to Berekely at 75 mph with 33s
8. * - since I didn't do it
9. As I picked it up
10. Project Stinky
10. Project Stinky
Grumpy-
Is that Dana's (RIP) old rig?
-Matt
Grumpy-
-Matt
Yes, and here's a weird coincidence. When I picked it up his wife told me their daughters lived in the Bay Area now. Would you believe I know one? Small world.
Ken K. told me no one liked following Dana on the trail due to the diesel smell hence the name Project Stinky.
Grumpy,
Thats an awesome story funny how the older i get the smaller this world seems to be :-) I got to run a few trails back in the day with Dana and that rig. Good to see she lives on and is still in the hands of a Mud member :-)
Cheers!
Updating the status of my Chevota project
I have put a couple of posts on related discussions that I thought should add. As with any major conversion projects, there are some modifications that need to be made to improve on your project. One is about adding gauges, and another focuses on updating the coolant system.
1991 FJ80 with Triple Gauge Set >> https://forum.ih8mud.com/diesel-tec...-your-gauge-install-photos-6.html#post7190333
Managing Coolant Temperatures on Modified Vehicles >> https://forum.ih8mud.com/diesel-tec...d-diesel-swap-build-thread-3.html#post7192785
Also, considering the engine has been in the vehicle since late 2010, I thought I should get off my butt and get around to showing an image of the engine bay.
[QUOTE
Also, considering the engine has been in the vehicle since late 2010, I thought I should get off my butt and get around to showing an image of the engine bay.[/QUOTE]
Dude- That has to be one of the cleanest 6.2 / 6.5 installs I've even seen! Nice job!
-Matt
I was thinking the same thing. What donor vehicle did you use for the hydro boost setup and what modifications did you have to make to get it to work?
1- 91fj80
2- 6bt,g360,np205 d60 front 70hd rear drw axles
3- Fitment. I mean it was a tight fit but the drivetrain fit real well.
4- Fuel tank. Paid to have a custom tank built to go where the spare tire goes. Was cheap but was the hardest part of build so not bad.
5- Front 3 link and custom tank as mentioned
6- Drives a little smoother than most of the lifted rigs I've driven. Waiting on the right shocks to show up so its a little slushy feeling.
7- Shooting for 20mpg. Seeing as it was making 8 then I should be happy. :)
8- Going with a 5 star. My buddy has a shop with an overhead crane and made the job much easier as we could pull the drivetrain many times to get the fitment just right.
I have a build thread but it's not on this site. :doh:
Well I've been done for 6 months or so, so I guess I should add it to the list!
1996 FZJ80.
1HD-T/A442F, bought a complete HDJ-81 that had been lightly rolled
As stated before, this stuff bolts right in, even had all of the right holes to mount the fuel filter assembly. Swapped fuel tank, lines, filler neck, even swapped the JDM locking diffs in!!
The wiring was a bit of a chore (I installed the JDM guage cluster in my dash) Took me a pretty solid week to get everything happy again, I think I was soldering in my sleep!
Boost to 17psi, Rage big bore pipe, Chromoly axles and Birfs, part time kit, 2.5" OME, 1" spacers, Safari snorkel, Arb front bumper, Custom rear bumper, Custom sliders and roof rack
Has a little more pep now, FZFE was supercharged so they have similar acceleration. The diesel feels more effortless and is torquier off the line for sure.
I'm getting 21-22 mpg... better than 11!!!!
** for the "hardware" **** for the wiring
No thread...been done before
This thread rocks!
Anyone know of guys converting 100s yet? One guy in canada has done. I was just wondering if anyone in USA has done it.
  • Back
