Diehard PM-1 Battery is tired... need a replacement
Pacific NW
I've been running this battery for +6 years and it seems to be discharging on its own (unplugged from car). The closest replacement I can find is the Odyssey 31M-PC2150. Posts are slightly different but man is it expensive ($400). I don't do any overlanding or camping... I just need something to start the truck and turn the Warn 9.5XP often.
Costco has the Interstate MTX-94R/H7 for $180. It isn't nearly as beefy as the Odyssey, but seems like a good value that should do the job.
Anybody have thoughts on this Interstate? Or other ideas for a $200 battery.
you can get the correct post orientation if you search for battery sizes that have an F after the numbers - if you reverse the posts, you will need to pull really hard on the cables, not a good idea
we are running the Batteries Plus extra power 27F in the 80 and LX - $365 out the door in Arizona
Yup a 27F is the right post configuration for the 80 series
Im running a 27F Optima yellow top, so far so good.
Not sure what you're referring to. Both batteries I mentioned fit without issue, both size and cable wise.
I like Deka batteries and you could stuff a 31 series in there and run other things without a second battery :steer:
