I bought a front axle rebuild kit and a set of front brake pads. I have a local mechanic at the dealership that helps me maintain my fleet. He did a front axle rebuild. Seals, bearings, and new lube. Installed the brake pads and turned the rotors.
The service manager said he thought the starter was going bad. I got a new starter and set out this morning to install it. The truck had been sitting for a few weeks and now the battery is dead. The battery is new; only a few months old. I jump started it.
I’m wondering now if there’s a parasitic drain on the battery that causes the truck to act like it needs a new starter. The starter in the truck looks pretty new. It’s still shiny in fact.
A common Issue with the dead Battery is the driver door, when you open it lights up the ring around the ignition. The switch that operates this is in the door jam it gets out of adjustment and even with the door fully closed the light dose not turn off. in the short run not a problem let it sit a few weeks = dead battery
For mine I just moved the door catch in a bit to make the door close tighter.
