D'animal 1970 FJ40 Landcruiser
totally cool! I would have never guessed how far that dual shock remnant could be brought back! I will never doubt Rob and his collections again! SWEET. Keep it up D'Animal!
Another piece to the puzzle found and donated.
Thanks FJrome!
subscribed!!!!
Build a gauge cluster out of my best parts. I really need a speedometer since the input crossshaft is worn out.
I installed a new ignition switch and wired it in and installewd a newer headlight switch and wired it in.
Looking at the the holes nearest the engine, you can see the shiney metal from the drill bit.
After you knock out the weld on tabs you can shave the side of it down and use it against the firewall/dash support.
Nice! :popcorn:
Dan you are the man, still waiting till I can make a trip to see that 45ec of yours. keep doin that thing you do.
to funny, i was just thinkin bout doing this, and then I find this thread.Looking good.Ive got almost to many spare parts....almost.
The clutch fan is the hold up.
Engine is a 2F from a 1984 FJ 60.
I cannot find a smaller OD fan to fit in the FJ 40 schroud that will work on the larger clutch fan diameter.
The 1976-1978 fan uses a smaller fan clutch, smaller bolt patern and a smaller bolt diameter.
Looks like I will have to swap waterpumps.
