1970 fj40 carb adjustment
Massachusetts
Have a 1970 carb with mechanical secondaries What base line setting to start tuning for idle speed and idle mixture screw had it running decent added a recurve distributor and throttle cable was adjusted so stating over i will be using vacuum gauge and rpm gauge thanks
Check out youtube, OTRAMM carb tuning vid. Fellow mudder. @OTRAMM
It's a wonderful video and worth the watch.
Yes have watched that method very good just wondering any different on 1f carb
There's not much difference between the basics of it.
Carb tuning is the same across all carbs period. Lean drop/mixture setting is a universal method, so pick your preferred idle and set mixture according to that speed.
