You mean that seal? No, not touching it....
Aaah if you are in there.. u might as well replace the differential-CV seal... else if it leaks you'll be doing this all over again. I should't have to say it but use the OEM seal.
Do it once, Do it right.
When you say diff-cv seal, you mean the following one, right? If so, yes, I'm replacing it with the OE one.Aaah if you are in there.. u might as well replace the differential-CV seal... else if it leaks you'll be doing this all over again. I should't have to say it but use the OEM seal.
What I was asking is the seal in the spindle, not the diff-cv one.. Wasn't sure if the channels on the surface was expected. However judging by its shape, I believe it is what it is.Just to confirm, the channel on the bearing seal is expected, right? My first thought was "damn......"
By the way, how could I grease the needle bearing inside the spindle?
The yellow one requires a crimping sort of tool. I bought one from NAPA that was a POS and resembled pliers, but forget why typical pliers didn’t work as well. Pretty sure on this thread I mentioned them last year.Welp, s***. Both of my inside boots just ripped at the same time after a couple of years right at the band clamps. The other joints are all using the OEM style clamps, so that's interesting. Possible I tightened the band clamps too much? IDK, I guess something to watch out for. This happened on strictly highway driving. Anyways, I need to replace the inside boots now, are there any special tools required to use 1 of these? Looks like the yellow maybe doesn't? Thanks for the guidance.
The POS pliers I bought didn't work well either. I ended up experimenting and realized a PEX crimping tool I had might work and it did. I think I have this one: Apollo 3/8 in. to 1 in. 1-Hand PEX-B Pinch Clamp Tool 69PTBJ0010C - The Home Depot - https://www.homedepot.com/p/Apollo-3-8-in-to-1-in-1-Hand-PEX-B-Pinch-Clamp-Tool-69PTBJ0010C/301921125The yellow one requires a crimping sort of tool. I bought one from NAPA that was a POS and resembled pliers, but forget why typical pliers didn’t work as well. Pretty sure on this thread I mentioned them last year.
I curious, as to which clamps you have/had, that rip the boots? Pictures?Welp, s***. Both of my inside boots just ripped at the same time after a couple of years right at the band clamps. The other joints are all using the OEM style clamps, so that's interesting. Possible I tightened the band clamps too much? IDK, I guess something to watch out for. This happened on strictly highway driving. Anyways, I need to replace the inside boots now, are there any special tools required to use 1 of these? Looks like the yellow maybe doesn't? Thanks for the guidance.
forum.ih8mud.com
I would use compressed air in conjunction with the parts cleaner to push as much out of the birf as possible. Or do repeated plunges in parts cleaner then compressed air. YMMVHow long do we need to wait (if at all) before rebooting and repacking grease into the outboard end of the CV after cleaning it? I sprayed pretty good in there with about half a can of parts cleaner. View attachment 3608268The consistency of the old grease went from goopy to somewhat more liquidy, and I dabbed up whatever dripped out with paper towels.
I guess I'm just worried if there's solvent still trapped in there, will it ruin the consistency of the new grease?
