Eyedaho
I'm pretty sure I have swapped FDS/CV by just turning the steering to full lock towards the opposite side, but I can't remember for sure. I may have also had the upper BJ separated. Of course best practice would be to remove all of the things, but ain't nobody got time for that!@Dirt J No, that sounds like good advice, I agree that I've been fighting against the weight of the assemblies, even with a solid floor jack to prop stuff up. I have ball joint tools/air impact wrench. I just didn't want to remove more stuff than I need to. I can take whatever I need off. I just only had to take off the top ball joint to get the old axles out, but even that was a tight fit. The new axles are stiffer of course.
If I had to pick one for clearance, should I take off the lower ball joint or the tie rod end to help get some room? My gut feeling is to take off the tie rod ends just because they are generally easier than ball joints. As long as I don't screw around with them anyway. It's been a while since I had an alignment so that doesn't matter.
On that note, I ought to mark the tie rod ends and count the revolutions if it gets messy. Damn. Maybe lower ball joints then? Haha. I don't know which is the lesser of two evils here.
