Dirty Koala
Nobody makes one, we have one in the works though.![]()
AWESOME!!!! I can't wait to hear more about this.
Sorry to muck up this thread.Nobody makes one, we have one in the works though.![]()
Inter cooler is still in the plans if it will fit. When I first decided on the 6bt I knew adding the inter cooler would be iffy but Jonseys thinks they can make it work.nice! Mr Cimarron, what year engine did you get? is it VE or P pumped? will joneys be installing an intercooler (as it seem like your engine came with one OEM).
I'm not a heavy foot driver so I think for me the axles will hold. The NV4500 manual trans was behind the 6bt from the factory so I'm not worried about that at all. I mainly chose the 6bt for better mileage and obviously more power. More power to me means maintaining speed on hills not 0-60.how do yall think the trans and drivetrain will handle a P pumped intercooled 12 valve? from my research, that engine would have 10% more tq than the VE pumped non intercooled engine that is in the predator.
sorry for all the questions, planning my swap and am trying to learn as much as possible.
Another thing I think Jonesy's needs to correct on all engines they see is the KDP. You're a damn fool if you don't while it's right there.
EGT and boost gauges are getting installed. KDP has been discussed as well.Depends on the year of the engine and what trans came behind it.
An NV4500 behind it, no sweat but he ought to be getting a southbend clutch while he's in there.
Axles... well they should hold up if he goes easy.
See Cody's build, he's mentioned he's toasted a few 9.5"s getting crazy with his.
Mine will be getting a 14 bolt and chevy 63s in the rear, and a KP chevy 60 up front on a 3 link.
Also I'd be installing a pyrometer even with a stock pump if you don't end up installing an intercooler, it's a good thing to have regardless.
