Depends on what trans you run behind it. If you run a 6 speed with double overdrive you could go as low as you wanted. These kind of projects are all about planning. What are your goals and how do you get there is what a good project manager does.
So this engine package isn’t really ideal for someone who wants to crawl as slow as possible with a stock trans and transfer case even with the current lowest low range gear set? Seems that way if you plan to run 3.7’s and 34” tides.
