Sometimes the "ear" of the intake is slightly (just .010) or so pulled away from the flat of the manifold gasket surface. I noticed that on my son's intake manifold on his '77. That intake had never been surfaced after it was manufactured. If it had been surfaced flat, the ears would have been even with the gasket face. As it was, the very slight gap at the ears for the mounting nuts allowed extra clamping force for the gasket. The aluminum ears could "give" a little under the nuts until they pulled down hard against the completely flat exhaust manifold ears. I did surface the gasket face of his exhaust manifold. As a result, the flanges were thinner on the exhaust manifold than they were on the aluminum intake. That would result in uneven clamping if it were left like that. Rather than grind down the thickness of the intake manifold and weaken the casting, or using split washers, I built the nut side of the exhaust manifold ears up with some brazing rod and then used a vertical mill to get the thickness matched back up with the thickness of the intake ears. That way I had a nice "flat" for the washer to rest against as the nut was tightened. So far, his intake and exhaust are holding up nicely with no leaks.
BTW, at the same time I did all the above work, I also milled off the area of the intake manifold where it mated to the exhaust. Here in Texas, it is already plenty hot and we didn't need the additional heat transfer from the exhaust to the intake. After milling, there was enough of a gap to put a mating gasket and a 1/4" thick piece of steel as a block-off plate on the exhaust manifold. I removed the heat riser and welded up the pivot holes in the exhaust manifold. Now he doesn't get any heat-soak and doesn't need a carb cooling fan anymore. I have photos of this if anyone is interested.
