Compiled 80 series suspension component spec thread... shocks, coils & more. (16 Viewers)
And here is my shock travel with a 10” travel Fox 2.0 remote reservoir, eye to eye with upper mount eye adapter dropping the mount 1.25”.
Bumpstops are dropped 2”, which perfectly protects the upper travel limit.
That’s right in the center of the shock and spring travel and for me a perfect application of these 4” Flexi coils. Dialed.
Has anybody run King shocks on the Dobs Flexi coils? I am on Kings shocks with comp adjusters and OME J springs. I'm planning to get the King front and rear bump stops also, but would most likely get Dobinsons flexi coils to test them out. The ride right now is actually really nice, and the springs stay captured when wheeling, so if there isn't a huge difference in ride and weight carrying capacity, I may stay with the J springs.
I would love to see how this plays out. I have been considering something like this as an alternative to the Icon stage 2 kit which I have been considering. I have been looking for a nice <$3k 2.5 setup. The slinky stage 4 seems great and all but out of my price range. Since King shocks is local to me they would make the most sense for service.
Anybody know where to get Kings for a good price?
Filthy Motorsports. Budget 5-8 weeks for delivery. Mine were 6-7 weeks to my door.
Look up @jtwopark his 80 was the R&D rig for King. I think he sells them also.
@jtwopark what is the comp. & extension of you 2.5 Resi shocks?
I found this in anothet thread. It gives the King shock specs. Although they have a 0-2" inch set and a 3-6" set available.
Shock Length Options List
It would be great to get all the available shocks length specs togather in one place!
Slee has theirs published as:
Front SOF1227: EXT: 18.0" COMP: 12.5" (STROKE: 5.5")
Rear SOF1230: EXT: 25.2" COMP: 15.2" (STROKE: 10.0")
More Specs stolen from: Wallowing Pig needs new shocks, so how about entire new suspension upgrade? and consolidated from posts below.
Bilstein:
Front BE5-2739: EXT: 16.08" COMP: 10.39" (STROKE: 5.69")
Rear BE5-2740: EXT: 21.71" COMP: 13.67" (STROKE: 8.04")
OME:
Front 60000: EXT: 17.44 COMP: 11.73" (STROKE: 5.71")
Front n100: EXT: 17.32 COMP: 11.42" (STROKE: 5.91")
Rear 60002: EXT: 24.10 COMP: 14.49" (STROKE: 9.61")
Rear 60071L EXT: 26.50" COMP: 15.24" (STROKE: 11.26")
Rear n101: EXT: 24.02 COMP: 14.17" (STROKE: 9.84")
KING:
Front: EXT: 18.64" COMP: 12.59" (STROKE: 6.05")
Rear: EXT: 25.11" COMP: 15.27" (STROKE: 9.84")
FOX:
Front 985-24-066: EXT: 17.55" COMP: 11.55" (STROKE: 6.00")
Rear 985-24-009: EXT: 26.15" COMP: 16.05" (STROKE: 10.10")
Rear 985-24-067: EXT: 22.95" COMP: 14.35" (STROKE: 8.60")
ICON:
Front 57607: EXT:17.8” COMP: 12.85” (STROKE: 4.95”) internal reservoir (IFP), use with stock upper arms.
Front 57807: EXT:18.18” COMP: 12.85” (STROKE: 5.33”) remote reservoir extended travel. MUST use aftermarket upper arm
Front 57807C: EXT:18.18” COMP: 12.85” (STROKE: 5.33”) as above W/CDC compression valve. MUST use aftermarket upper arm for shock clearance.
Rear 56510: EXT:25.67” COMP: 15.6” (STROKE: 10.07”) 2.0” internal reservoir (IFP)
Rear 57802: EXT:26.3” COMP: 15.97” (STROKE: 10.33") 2.5” remote reservoir, W/ bump zone
Rear 57802C: EXT:26.3” COMP: 15.97” (STROKE: 10.33”) 2.5” remote reservoir, W/CDC compression valve and bump zone.
Talk to @David Otero from Dobinsons, he can meet your budget for the 2.5 setup. I just ordered a kit from him for less than $2500
I ended up getting the Radflo 2.5's and Dobisons 2" progressive springs. I was able to keep it under $2k after gettinf a great deal on the Radflo's. The kings would have been $700+ more. I just couldnt justify it.
Does anybody have the Slinky coil specs for new part numbers and the corresponding lift and application:
from 4xoverlandusa.com @AutoCraft Aus @Box Rocket
70801FSLT
70811FSLT
70804FSLT
70814FSLT
70801RSLT
70811RSLT
70804RSLT
70814RSLT
70805RSLT
@GW Nugget it seems the part numbers you have in the Slinky section are not in use anymore. Or maybe the old part numbers match some of the new ones, thanks!
70801FSLT
70811FSLT
70804FSLT
70814FSLT
70801RSLT
70811RSLT
70804RSLT
70814RSLT
70805RSLT
Well, Kevin aka @dockbox with www.endlesshorizonsoutfitters.com and Darren with www.4xoverlandusa.com @AutoCraft Aus should be able to help us with that info. Official specs from the mfg. would be nice also...
I did some reading today & update post #11
Pro Comp E9000
Pro Comp ES9000 Shock Information and Specs
20180317_135832-png.1656231
Model Body Min Max Range Upper Lower
924530 2.36 14.56 24.50 10.12 Stud Stud
924514 2.36 14.52 24.70 10.18 Stud Eye
927530 2.00 16.27 27.76 11.49 Stud Stud
927514 2.00 16.27 27.76 11.49 Stud Eye
Some use a U bracket on this shock below for loner ext.
927510 2.00 15.80 27.29 11.49 Stud Eye
Contribution to post #7 about TJM springs:
Info I got from TJM when I was researching their spring rates. I was looking for a rear spring for my 100 that kept the ride near-stock when unloaded, but could handle some camping gear. My rig is kept light and minimal. ARB 862 with spacers was what I purchased, but I wasn't sure how spacers would last. I wanted to get around a 2.5" lift with all spring, and have the comfort of a dual rate or progressive spring. The 80 and 100 can use the same rear springs and shocks. Looks like there's a lot more options available in the last year for me to research.
Hi Tim,
Spring 770RR80C has a free height of 510-520mm and a progressive rate of 145-250.
For comparison the 1" lift 770RS80B has a free height of 460-470mm and a rate of 200.
Phil Damon
Hi Tim,
Phil Damon
Thank you for you contribtion.
Those are really short in free height.... only a stock length shock would work to retain the coil, but yeah.
The real thing is most don't know the 100 can use any 80 coils. I just learn myself not to long ago.
Awesome Qball.... will you list the specs so we dont miss read the pictures.
Then I can post it on the 1st page.
You already have the specs on the King’s section. :clap:
Here is the picture of all 4 of them.
