COMPILED - 80 Series Seat Swap Thread
Question from someone who's never swapped seats before...
Since there are aftermarket seat brackets already made to bolt into the 80--why make custom brackets from scratch, instead of attaching your new seat-of-choice (whether that's aftermarket or some other oem) to a Planted or Wedge bracket etc.? Wouldn't it be easier to (for example) make an adapter plate(s) if the holes don't line up? Clue me in here...
Easier? Maybe
For me, aftermarket adapters weren't particularly readily available, without paying huge amounts for shipping, and without having certainty they would work, so it wasn't gonna happen.
Plus, I'd rather spend $100 making something than $200 on something i can make myself.
If you had certainty an aftermarket seat and aftermarket mounting bracket were going to work together, then yes, it would probably be easier.
I don't like the idea of buying an aftermarket bracket, then adding an adapter plate between it and a seat.
Every bolted connection is a point that can move. If things are offset too much without direct load paths, a seat can put a lot of leverage on brackets and bolts.
I have experienced this with seats I've modified for other vehicles
If you're retrofitting seats from a different vehicle, the seats will have brackets unique to that oem. They may be universal across several models built on the same platform, but aren't likely to just drop in to another vehicle from a different manufacturer.
If you're installing aftermarket seats that are more generic/universal in design, then aftermarket brackets may also be a good option.
Your 80 series has 8 different brackets for the two front seats. The bracket for each corner is unique or asymmetrical. So are seat frames.
When I fitted Audi seats, I found the sliders were similar enough in shape and widtth/ spacing that cutting the 80 series seat brackets off the seat, and trimming them to adjust height before welding them onto the audi seat rails worked well
Ah, thank you for the details. Alas, I'm not a welder...
Test fit of Nissan 300zx seat.
Land Cruiser seat rails bolt straight up to the seat and the measurements are also correct for the floor mounting points.
No interference with the transmission tunnel. I will however still be cutting the feet off and welding them to the Nissan seat rails, so I can properly mount the seat motors.
The seats are from a RHD Japan car, both powered back/forth, recline and tilt.
Anyone know the p/n for the FZJ80 seat power electrical plug? The one attached to the seat, not the car
People don't mention it in the post, but the big-bodied friends here can mention which chairs suited them and which ones they regretted buying?
I'm 6'0" and a buddy of mine swapped in the WRX seats, whcih I thought about doing in mine.
I'm glad I sat in his...most uncomfortable seats for a bigger guy (then 305 lbs)...the high seat arch was a PITA to get in and out of and the side area at your mid section was uncomfortable!
View attachment 3891057View attachment 3891058
What year of 300zx?
Looks great!
Big fella says Thank you!
Question to those who swapped in Procar Elite Lumbar:
Did they end up higher, lower or the same height as the stock seats?
Thank you.
Thought I would throw mine in here. Thanks to all for the inspiration. These are 2018 Volvo S90 Inscription trim seats. Heated, ventilated, leg extension, lumbar, etc, etc. Not sure I would recommend them due to amount of crap to make them work, but they are gorgeous and comfy. I loved them and made them work. They require a Volvo CAN bus signal to wake them up, then the onboard ECU's do the rest. Still working out the heat and ventilation functions, as well as the bolsters, etc. Used the planted brackets and added steel plates to extend them since the base of the Volvo seat is wider and longer.
Any pics of the extended brackets and how they fit against the tunnel etc. ?
Thinking of doing similar for SK Forester seats.
Don't judge my hack job... but I did have to cut out some of the bracing
Anyone try installing front seats from a BMW convertible? The stock power seats are very worn and motors need to be repaired or replaced. I've seen the BMW 3 series seats installed, but I was thinking of the convertible as they have the seat belts integrated into the seat. The driver is very short and I thought this might make it more comfortable.
Thanks
