Cable Lockers
Broski
I love Wheelin my 80
At the edge of the Pacific ocean
Anybody running them ?
What cable lockers exist for these? I've run them on a yj before.
Downey off-road used to make the me for the Tacoma e locker. Had swapped the elocker rear axle into a 1985 4runner. The cable was a pain to use.
LCE performance make a kit.
Trying to see how they are to use.
Not for an 80 as far as I can see.
Look again 😉
I thought I heard somewhere they were an OEM option on some of the overseas Cruisers, maybe different series though
Yes 70 series
Here Another one for the rear
I have no issues with the E lockers other then You can’t engage the front locker first.
And there’s no good work around that I can find.
FWIW, 80 rear elockers have been retrofitted into a fair number of 40 and 60 series cruisers without the original wiring/ecu.
Here is info I used to wire up an elocker for use in my FJ62. 2 DPDT relays, a SPDT switch, a couple indicator lights and some wire.
I used the first diagram shown with 2 DPDT relays (normally closed terminals ignored) and instead of having separate locking and unlocking lights, I wired one "motor" light in parallel with the motor. I used a spare power antenna switch as a momentary SPDT switch to activate the locker.
I now have 2x elocker diffs in my FJ55 that operate independently with this wiring, using repurposed tailgate window switches to activate.
12 volt guy has a kit also> On my toyota truck i installed factroy lockers on both axles I can turn them on and off in any order I choose. I think the kit I first bought was from Inchworm ,who has long since retired.Low range bought them out and I believe they are now part of trail gear.
