Well the 10" ram is in and done.
I learned a lot during the process.
1) 10" of throw lock to lock is max on a stock front axle housing, at least on mine.
2) The way I have the ram mounted it turns more to the right then the left
3) The way I have the ram mounted it moves the tie rod more then the 10" of travel the ram has. By about 1/8"
I think this has to do with the way the tie rod moves closer to the axle as you turn.
All of this had me scratching my head and chasing my tail
4) Makes perfect sense, but every time you adjust your toe in you need to adjust your steering stops. I just never thought about it before
I was dead set on getting it right this time so there was a lot of time laying on that piece of cardboard
The first thing I found was that with the 9" ram it was truing about a 1/4" more to the right then to the left, then I could not get more then 9 3/4" of throw out of the steering so I started looking to as why.
It looked like the steering knuckles were hitting the knuckles ball braces that I welded in years ago, so I spent time grinding them back I got a little more but still not 10"
That led me to the Tie rod It was a used replacement and I thought it would be close but not. It was toed out 1/2" instead of being toed in 1/8" again it got me closer but not to 10"
In my mind that only left one thing the steering box, So I disconnected the drag link sure enough the box was not centered and keeping it from getting full throw.
On closer inspection I found that the pitman arm was off two splines on the sector shaft. My bad as I sent the box out to be rebuilt and ported a few years back
Only this time I could not get the dam thing off, so I went and rented a pitmam arm puller but it was a POS and I still could not get it off. so I bought a good one and got it off.
Got the pitmam arm on in the right spot, centered the box and reset the steering wheel.
Then went about finding center with the Knuckles and getting the toe in set.
After that was all dialed in with a big square clamped to the axle housing I marked center full right and full left.
From there I could get placement of the ram mount on the tie rod. the axle mount is a hard mount and has to go were it is. getting the tie rod mount right is crucial to get equal turning both ways.
Turning the steering all the to the right and then pull the ram all the way out and then mark the tie rod, then turn all the way to the left and collapse the ram all the way and mark again.
In theory the marks should be the same but they were not this is where I fingered out the ram was traveling more then the tie rod.
So at this point I decided to shim down the ram to 9 3/4" which is still tight. this give it 9 7/8" of travel with only a 1/8 extra 1/16" each way.
At that I had to play with the ram adjusting back and forth tell I had the travel just in side the the two marks I had made earlier.
Each time checking to be sure that I was hitting the steering stop on each side and that the ram was making full travel.
All of this was very time consuming and frustrating.
In the end I think it all payed off as it turns equally both ways, turns much sharper then it did with the 9" ram a win - win
It will get full tested later this week at Fordyce trail, hopefully all goes well
