Brake job going off the rails…
  • Thread starter RevISK
  • Start date
  • Watchers 6
R
RevISK
sunset valley, tx
Happy new year Mud brothers and sisters,
1980 (April) FJ40…
Finally got Ol’ Patches running consistently and wanted to drive it around the property to work the diff’s for a fluid change, however, I’ve read that being able to stop is important too.
Began by removing the drum on the LR (with help from old posts here, thank you) and surprisingly, things looked really good in there. Seems someone did a complete brake job years ago and never really drove it after.
Plan was/is to flush all the old nasty fluid out and saw a vid where a guy shows how to flush and fill as a one man show.
Anyway, was able to bleed the line a bit using a hand pump bleeder but when I set up the self draining set up (hose from nipple into a hole in a plastic bottle where the end stays below the level of old fluid so it doesn’t pull air back into the line) and went to pump the brakes expecting fluid to gush out. Nothing. Not one drip.
Before I plop down more coin and buy a new master cylinder or vacuum booster, does anyone have any ideas?
Thanks in advance,
Ian
P
Pitter Patter
Renton, WA
It can take a bit of pedal pumping if there was air in the line. Just keep trying
Pighead
Pighead
Stop calling it an FJ
Camino
So, your drums are back on and there's brake fluid in the reservoirs?
Pighead
Pighead
Camino
I don't suppose your reservoir ran dry sometime during your adventure?
A10Driver
A10Driver
Doing it that way won't work if there is any air in the system. Get someone to pump up the pressure and then crack the bleed nut
R
RevISK
sunset valley, tx
It certainly got low while I suckling out the old gunk from there but never empty. Well, come to think of it, it did get pretty dang low on one suck out though I was adding fresh fluid to avoid it but it was a bit of a dance. So while not “dry”, certainly probably too low.
R
RevISK
sunset valley, tx
Ok, I’ll try that. Just happen to have a 10 year old with no interest in such things but his legs are long enough.
Pighead
Pighead
Camino
Well, you might have got an air bubble in your master. That's hard to bleed out sometimes.
If nothing else is working you might need to bench bleed (or firewall bleed) your master.
I use 2 short lengths of brake hose bent into just the right shape to feed back to the reservoir.
20211022 121406
20211022 121432
R
RevISK
sunset valley, tx
That’s an interesting idea, I shall give that a shot.
It seem I have a clog or collapsed line somewhere, I’m not getting any fluid now even went to the degree of disconnecting the brake line and removing the bleeder and blowing compressed air through the line. Nothing comes out.
Report back soon.
Thanks y’all.
Curtice
Curtice
Issaquah, WA
Not to sidetrack too much, but is bench bleeding the master necessary? I’ve put all mine together and am in process of bleeding the brakes (found out I have a faulty wheel cylinder, so have to wait to finish until I can fix that).
New master cylinder and I’ve got fluid in there, but I never bench bled the master…will that cause issues?
DSRTRDR
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
I have not seen a difference - first install was without bench bleeding, in 2005
second install was end of 2021, this time with bench bleeding - air got into the system nonetheless, so we went with the 2-person method for bleeding
Curtice
Curtice
Issaquah, WA
Cool thanks. I’m using the two person method to bleed the whole system.
I also did my other 40 without the bench bleed and havent had issues.
dial square
dial square
USA
I went through this process recently after replacing the MC on my '79... The ream drum brakes nearly drove me to madness. They just wouldn't bleed. I tried a hand pump vacuum and a power bleeder. Nothing worked. After scouring the threads here, I was finally pointed in the direction of the Coolerman Method, which, among other things, involves resetting the drum brake pistons before bleeding. It seemed counter-intuitive at first (and more work-intensive than I imagined brake bleeding should be), but after weeks of suffering I printed out the guide and went to work. I had rock solid brakes by that evening. Since you have an '80, I assume your front brakes are disks, so only the rear drums need to be adjusted. It is definitely a two person job. Good night and good luck!
Similar threads
a77fj40
Replies
1
Views
122
igotta40
J
Replies
3
Views
170
cruiserkev
cruiserkev
S
Replies
2
Views
193
Sunnyside up
S
Thewjsand
Replies
9
Views
220
3_puppies
3
