- Joined
- Oct 22, 2002
- Threads
- 174
- Messages
- 5,462
- Location
- Durango, Colorado
- Website
- www.durangomagazine.com
Sweet! How big a tire can I run?![]()
Not sure but 28" beadlocks would bring the bling.
Mickey Thompson Baja MTZ P3 35x12.50R20LT!
HEY!!! How come you got TURBO stickers with yours.![]()
Found Wits-End sticker no TURBO![]()
For those who are running 35/37 inch tires. Once you install the turbo, is there still a need to re-gear?
Thoughts on how stupid 35s/5.29s and a turbo would feel? Would I live my entire life in boost (not that I would really complain about that I guess)totally happy with 35s and stock gears. Perfect for frwy
I ran the math on the stock tires/gearing versus 37" tires/re-gearing. The stock tires are 275/70 R16's, which are 31.2" in diameter. The stock gearing is 4.10.For those who are running 35/37 inch tires. Once you install the turbo, is there still a need to re-gear?
I am going to run 37 x 12.5 x 17" Milestar Patagonia tires. They measure 36.8" in diameter. The new tires are 17.9% larger in diameter / circumference (Pi*D=C)
To have the same RPM at any given vehicle speed, the gearing would need to be 17.9% lower. 4.10 * 1.179 = 4.84.
The rig I bought last year does not have factory lockers, so I had to put ARB's in anyway. I re-geared them to 4.88 at the same time. The rig will run at the same RPM on the freeway that it did with stock tires.
The math for 35" tires is not as convincing. If I were to run the Milestar 35 x 12.5 x17's, they measure 34.7" in diameter. This is 11.2% larger than the stock tires. Taking the stock 4.10 gearing lower by 11.2% would be 4.56 gears. So, 4.55's would get your right to the same RPM on the freeway that you had with stock tires. But the turbo motor is putting out more torque and that would compensate for the lost RPM with stock gears.
I concluded that if I were running 35's, I would stay with stock gears. I went with 37's and decided to re-gear with 4.88's.
I would take the turbo out of the equation.Thoughts on how stupid 35s/5.29s and a turbo would feel? Would I live my entire life in boost (not that I would really complain about that I guess)
Need to get better at prioritizing time for the land cruiser too! Cheers!
