Awesome! Great work.
Yes, it can handle up to 24volts.Am I reading correctly that this can be wired directly to a 24v system? I could use a few if that is correct.
Thanks
Abe
Awesome! Any chance you are planning to make a four channel version, or will 2 be it?Yes, it can handle up to 24volts.
It actually performs best at 24v 8ohm/38W*2; 4ohm/50W*2
I’m looking at getting a 4 channel or 2 plus sub.Awesome! Any chance you are planning to make a four channel version, or will 2 be it?
Thanks
Abe
That makes total sense. Last question, if I bought two of these, is there any chance they could be daisy chained to run a front set, and rear set of speakers that way? I don’t know if that sort of tech is automatic in BT stuff these days, or if it has to be built in seperately.I’m looking at getting a 4 channel or 2 plus sub.
Theres issues with size and mounting once you get into the additional features.
Llll SUpdate* I was able to get the first 10 in the mail.
I'm waiting on a resupply of units to fill the rest of the orders.
Thanks for the huge response!
I really think this is a great new way to get audio into places that either were never designed for it, or to add a modern update where you want to retain the original radio.
Did I mention you can run this along side a stock radio?
Thanks!Those are too cool for sure .
Any chance of you extending your audio love to the 60 series in the future. I was planning on sending out my original radio to be updated, but would rather support a fellow mud guy if at all possible.
You should make this BT-RADIO or BT-TEQI want to let buyers and potential buyers know to make sure you wire this unit to a SWITCHED power source.
It does draw a very slight bit of power even when switched off. Theres no memory required so it will not effect it whatsoever.
And once paired to your phone, it does a great job at auto - connecting.
Its name when searching in Bluetooth mode will be BT-WUZHI.
