$250 ??!! That's more than I paid for my 80!!!Here is the link for the set of and forget it version from @landtank and @NLXTACY :
80 Series 1FZ-FE Modified OEM Toyota Blue Fan Clutch
What’s wrong with the fan clutch you have?$250 ??!! That's more than I paid for my 80!!!
There's an easy option for a new oring if you don't want to mess with the old one:
Fan Clutch O-Ring
That's great to know
@NLXTACY where was this five years ago when my oring was too long,
In the memory bank for later![]()
@mudgudgeon Why and cutting it was a fail!?????????
Honestly one of the best bang per buck "mods" you can do to the truck. I have been thrilled with mine.Or don't replace the fan hub, keep the $250 in your pocket, and save it for the head gasket job, or rebuild that's in your future
At $250, it's cheaper than a new OEM here, and if it's pre set and pre filled with fluid, it's better value, and a fair price IMO
My fan clutch? Nothing. Course mine is a ‘94 and has the big transmission (doesn’t overheat like the ‘95 - ‘97s do), so.....What’s wrong with the fan clutch you have?
Asking for a friend. He has a ‘96 that was overheating weekend before last while we were off-roading. And to be fair, $250 is not that bad. I was just trying to joke around about how cheap my 80 was (less than $150 - no schitzki.)You said "Is there a fan clutch (blue one?) I can buy that's ready to be installed" so $250 is the price for not reading the thread, not buying from amazon and not following the instructions in this thread to setup it up correctly. Rest of us cheap a$$es who didn't spend 250 bones for the fan clutch bought from amazon and followed the instructions in this thread. @landtank didn't have to provide the information on how to mod the fan clutch and sell the only ones that would work properly out of the box. I've see OEM fan clutch from the dealer that DID NOT have enough fluid.
Also a quick reminder that an 80 like my LX back in 1997 money cost 67k or around 120k today's money. All land cruisers are designed to have service life of 25 years even today's LCs so quality parts will not be cheap, if that's an issues then might want to sell the 80 and join the jeep crowd. They have a lot more lower cost options on jeeps.
Ha! My dash has the authentically fake teak wood grain finish. Camry dash might be an improvement.Yea, but you also have to subject yourself to sitting behind a Toyota Camry dash every. single. time.![]()
Yes but to be fair, it looked like this:DAMN!!!! Did you really paid less than $150 your 80?
Each of my DIY oil change cost at least $60, tank of gas was $100 at one point in time......and we are headed that way again!![]()
I think I did something wrong...
I've read through the first 20 pages or so and am still reading. However, I decided to do this mod as I'm in the process of replacing the electric fans that the PO installed. I bought a brand new Aisin blue hub from Rock Auto and a 59ml/2.0oz bottle of Team Associated 20,000 cst diff oil.
I followed the directions back on page 1, only varying from them by using an IR thermometer on the back side of where that coiled spring is. Ie- as it sat in the water, I put the IR gun up against the center and measured there. At 95°F, I adjusted the plate and tightened the screws.
I filled the drive flange side up to the bottom of the four holes- maybe a bit more than that, actually, but not past halfway up the holes for sure- and bolted it all back together. There is about 1/3 of the bottle remaining. I did this while I made the adjustment and didn't wait too long for the oil to settle, but I did rotate the housing quite a bit and filled from different positions; the fluid seemed level.
Now that its back together, when I spin it by hand while holding it horizontally, I can feel some drag for maybe five or six turns and then it frees up and spins like there's nothing in there at all. I then heated the coil with a mini torch held at distance to get the ports to open up inside, and it behaved the same way.
Is this how it should be, or did I do something wrong? Since there's still 1/3 of a bottle of the oil left, did I not put enough in?
Thanks, Flint. I decided to just see how it'd work and went about installing it and the shroud... broke the shroud AND the nipple on the top tank of my brand new radiator. Mf'er... so, MORE parts inbound.
Yup, that will work fine. Although 10K is a little light. Most go with 15K, but looks like you live in the north, so might work fine for you locally.......... For those of you who have done this mod will this type of oil work? Or should I get the OEM Toyota stuff
