Got my modified clutch and installed it. Wow, I wish I had done this when I purchased my 1st blue hub. 80 owners without a scan gauge, RT modified or aftermarket where you can actually watch the temps can't appreciate the results. I used a 300 mile round trip run to test it, over 2 passes. Don't have a scan gauge, but from my RT modified temp gauge there is a noticable difference. Although it's not summer, it runs cooler, even idling. I'm estimating 10 to 15 degrees & faster recovery - that is back to normal after a grade. I think it's 15k clutch fluid that's installed, isn't it? That, plus setting the temp, truely makes a difference. I may have put in too heavy of clutch fluid on my original blue hub. I think I estimated around 25k - it was a mix of something like 30k and 15k. There was a formula and chart IIRC - anyway, my fluid plus not setting temp did not perform as well as this Wit's end blue hub clutch. This gives me back more confidence - like I had before with the OEM gauge, that only moved when you were already overheating...lol
Thank you Rick! Your skills are appreciated!
Thank you Joey for Wit's end!
Thank you both for making this available to us 80 owners. I highly recommend this to any FZJ-80 owner that's replacing their fan clutch.
