Blue fan clutch mod...Thread has gone to hell, read at your own risk
12 or 13, either way those are small nuts.
drove back from the North coast in 100 degree weather with some pretty substantial climbs on highway 101
Coolant temp never got above 203 :)
The real test will be next time I drive up highway 80 to Donner Pass.
But my nuts don't seem to have change drastically in size.
That is correct
Joey, somehow I missed that Wit's End had this modified by Landtank clutch...I just ordered one. I've had a new blue clutch for several years now, after my OEM black hub seized up. At that time, the choices were to:
1.) run it as it came; or
2.) Pop it open and adjust temp; or
3.) Pop it open and replace OEM oil with heavier oil: or
4.) Pop it open, adjust the temp and replace with heavier oil
I chose option 3, mainly because at the time I sensed a lot of confusion and disagreement as to proper method to adjust the temp. IIRC, Tools R Us & Landtank had 2 different ideas as to how this should be done. And I had little confidence that I could adjust temp correctly. Being that I have a '94 (OBD 1), scan guage is not available to run continuously. I have done the RT mod to my temp gauge, so it would give more accurate idea of engine temp.
But, I just have not been satisfied since with blue clutch and temp gauge mod - it seems to be running hotter than it should, especially with any load or incline. And on a recent run in hot weather, running the AC made it worse. So rather than trying to adjust my existing clutch, I'll try a clutch, modified by Landtank, who has the experience to do it correctly. I'm hoping for improvement and will give feedback. I can always keep my existing as a spare.
3FE is a completely different clutch.
so does the 3fe typically even need a modified clutch to reduce cooling temps or it is generally safe enough without any modifications to the fan clutch?
