Ah yes, now we're starting to pop boots. The memories are coming back. Here are the results of the numbers with the boost fooler installed and if I understood correctly with it fully shut (allowing no boost signal to the actuator). That mean it is drive pressure working against that internal flap in the exhaust housing that is opening your wastegate.
Total Boost | Large | Small |
5 | 1 | 3.7 |
10 | 3 | 5.7 |
15 | 4 | 8.7 |
20 | 5 | 11.2 |
25 | 6 | 13.3 |
30 | 7 | 15.3 |
Pretty much the same until 20 psi and then it looks like it is building better than before. Bummer that your large turbo boost gauge is not next to your total boost. I can see how this is harder to get numbers. I've got my total and large gauges right next to each other. I was watching the video to see if I could map out the results of higher boost.
In attempts to reduce egts I think you can work the small turbo even more, the challenge is now total boost. Can you remind me what exhaust housing size is on your large turbo and if it has its own wastegate?
If the large does have a wastegate I say get the small turbo to work more by adding additional preload to your wastegate actuator (add an external spring or tighten down the rod on the actuator) to keep the small working more before the large gets the additional exhaust flow. Then reduce the preload on the large's actuator to get that to open sooner which will let the exhaust escape and limit total boost and reduce egts.
If the large turbo does not have a wastegate then total boost is reduced by turning down the power screw on the injection pump. Reducing the fueling will also reduce the egts as well. If you have to turn down the fueling I'd still want to make the small turbo to work more.
Depending how you want to chase this if you don't want to turn down the fuel you then are looking at a larger more efficient intercooler and trying to get your intake to suck outside air and not under hood air. This is to help the egts.
@Jason Andrews talked about the use of turbo blankets and manifold wrap to aid in reducing under hood temps. The blankets also have the benefit of helping the turbo's spool quicker since they run off of heat. I've just picked up a pair of blankets to try out once I get my rig back on the road.
