- Joined
- Jun 21, 2011
- Threads
- 233
- Messages
- 21,821
- Location
- Redding, California
- Website
- trail-tailor.com
Mike,
Best option is ruled out -- Stitch n Lock or similar process, IMO
Next (if cast iron) would be to thoroughly clean and lightly grind a shallow groove, Get area upwards of 300F or a little hotter and weld with a NI55 or similar nickel based electrode... Then to assist in a SLOW cool down to help prevent re-crack, cover and pack the area with insulation until the temp has ramped down to ambient. Don't peak until a heat gun verifies the equalized temp..
IIRC -- I'll try and find it but Devcon?? makes an alloy friendly epoxy that will hold up the the temps.
If the base metal is cast aluminum go with a 4043 Aluminum wire. It has a lower Magnesium % (stay at or under 3%), softer and works the best in my experience. Even though 5356 is the most popular it is a bad choice for casting repairs.
GL brother.
J
GL brother.
J
