Alot of people with mini trucks and 4runners are using ford gas tanks:
http://www.pirate4x4.com/forum/toyota-truck-4runner/484247-who-used-ford-gas-tank-toyota.html
Dimensions: 34 3/4” x 27” x 7 7/8”
The ford E-250 van's gas tank looks like a great fit, and not too tall either. Cheap too, a new is just over $100.
Cool. Now, how to best support the fuel tank safely?
One thing I like about the aftermarket solutions is their mounting to the frame rails. Although the straps work well they are a little more difficult to install in a non stock location.
That looks like a decent candidate but I'm worried about the rear fill port. If you folks can visualize how the fill hose will get routed, I think you'll see that this will pose a problem. The fill hose typically has to have a large bending radius so this radius will smack the body as it comes from your filler neck solution to this point. Also, keep in mind that you must have a decent downward slope from the fill neck to the tank inlet; otherwise, the refueling process will be a VERY aggravating one. The fuel nozzle will keep stopping on you as the fuel backs up this hose.
I'm going to try to reuse the oem mounting solution (straps to the body) to see how easy that turns out. But, coming up with a frame mounting solution should be rather easy as there are several captive nuts inside the frame left over from the spare tire mounting thing. I think the MAF 24g tank may use the frame mounting solution if I'm not mistaken.
If you looks at the right side of the tank in that picture you will see the fill and vent port. No issues with the fill, the tank will need to be turned 180* but that's not big deal with it being a flat tank, in fact I think turning it will work well it will place the fuel pick up at the front of the tank as a benefit.
I dont think the flange on the tank is meant to bear the weight of the tank, unless you mean for the straps, in which case they wont wrap around the side of the tank as well to hold it in place?
A guy may have to construct a skid plate to hold it in place properly. I guess Ive got enough checker plate aluminum around to build one though.![]()
Looking at that tank, I'd think the strap solution would work out nicely unless I'm missing something.![]()
I found a tank here in calgary off of a 97 4runner on kijiji, I may go have a look at it this evening.
I also have two BJ60 fuel tanks in my garage, but I think they are too big, Ill have to check again.
I might be the one missing something
If your gonna use straps then it will be pressed tight to what ever is above it, and I believe the straps attach to something directly above it. Im not sure if, other than the bodywork, that there is a suitable place to attach the straps.
Since I'm not the one with a 4runner tank on hand or their straps, someone with those parts would have to make it work and then show us how they did it ;p
II can be more clear with my posts. If you follow George's mounting instruction linked above (Taskled.com), you'll see where the straps are attached to the body using rivnuts. You are correct in that the tank is sandwiched against the bottom of the cargo floor with these straps. IMO, regardless of what type of tank we end up with, as long as the top is rather flat, you can use the same strapping concept to mount the tank to the body. I think the straps provide a very cradle for just about any tanks. The only caveat would be if the rivnuts can hold up a tank with 25g of fuel vs the 14g they were designed for. Technically, the rivnuts are 3/8" 16 (in my case) and I haven't investigated their pullout specs. Realistically, we're only talking about an extra 88lb of extra weigh (25g vs 14g tank) so the safety margin is probably there.
