@flintknapper - Are you tracking your temps on the interstate? Around town mine usually stays under 190. Sometimes when I get on the interstate and drive 80 MPH running the AC in 90-degree weather, I see the temp climbing or cycling over 195. If I'm driving fast up an incline, sometimes it climbs up to 202. The highest I've seen is around 203 -- even when off-roading with the AC on. Fuel trims look great. I'm happy with the mileage. Runs great.
I have a new OEM thermostat (properly clocked), new OEM fan clutch, new hoses, new heater Ts, new everything. I am going to replace the OEM radiator cap just because I haven't replaced it yet.
One thing to note is my LX didn't come with any foam around the radiator. It seems to be fitting right.
I'm confused about how I would install foam and what it would do?
Do I have anything to worry about?
I'm running Toyota pre-mixed pink. I like it because I run it in Tacoma and the Nissans. I typically change coolants every couple of years. Having everything running the same coolant lets me stock up and change it more often than running a specialty coolant.
