Bearing repack GURUs
uHu- thanks for offering the info. I've followed the FSM to the letter, but the preload never gets much above 3-4lb f with a spindle nut torque value of 5 or 6Ft lbs. And to be fair, I don't even trust my digital 3/8" torque wrench to be very accurate at 5 ft lbs torque.
I've concluded that this whole process boils down to prioritizing break way preload- over adjusting nut torque (as it relates to the FSM). I guess time will tell.
Preface that everything bearing related is NEW: bearings, races, thrust washers, spindle nuts, lock washer, washers, nuts, cone washers etc.
Anyway after spending waaaay too much time trying to get the DS preload where I wanted it, I kept adding torque to the adjusting nut until I achieved consistent 13-14 lbf on the fish scale, buttoned up the DS and called it a day. It eventually took 40ft lbs of torque on the adjusting nut, but it just seemed like too much torque even though the break away preload was in the specified range.
With the DS done I was still unsure of my work. I started reading again. I read a lot of posts in several threads in both the 80 & 100 section regarding the torque values, FSM instructions vs achieving FSM preload values. Lots a varying detail. But it seems many of us have had the same issue of requiring higher torque values to achieve break away preload to FSM specs.
Kudos to 2001LC who has thoroughly documented a comprehensive list of experiences relative to this process which builds on several years of posts and thousands of miles. Many Thanks!! All this led me to some worries about my work: Maybe too much adjusting nut torque because I had a lot of excess grease on the bearing faces & races, & thrust washer. I had grease on the spindle threads, and a very liberal amount of grease on the spindle itself....I think too much grease everywhere. I think this was affecting the torque requirements & preload settings.
On the PS I tried a different approach. I had read several posts on setting final torque on the spindle nut to 25ft lbs (Tools method). So I wiped the excess grease from the bearing faces, and races. I applied a very thin film layer of grease to the spindle. Slid the rotor on and installed the outer bearing , thrust washer (dry), and adjusting nut(dry). Torqued to 43ftlbs to seat the bearings and backed off and repeated a few times. I then torqued the spindle nut to 25ftlbs and checked preload and got 11-12 lb f consistently.... bingo. I torqued the locking nut and measured again; averaged 13lb f. Good to go.
Based on the stellar results from the PS I went back and pulled the DS apart and started over. I removed the rotor and cleaned the excess grease from the bearing faces, thrust washer, spindle and threads. Replaced the rotor, and went through the same process: 43ftlbs to seat bearings, back off & repeat a few times. Then set to 25ftlbs and checked preload: 8.5-10lbs. I increased the torque to 28ftlbs- got close to 10lb f preload consistently, then increased torque again to 30ftlbs and got 10-11ftlbs and stopped. Installed locking nut torqued to 47ftlbs and checked preload and got consistent 12.5-13.5 lbf. Set the lock washer in place and called it a day. The takeaway here is that it took less adjusting nut torque to get preload in range by wiping away the excess grease.
I think my DS spindle is worn, worn enough to require more adjusting nut torque than the PS to achieve the same preload. Does that make any sense? Another indication was the PS side felt completely different the from the first point that I installed the rotor on the spindle. It felt tighter, there was more resistance, and it was quick to settle and torque. The snap ring on the DS is also 1 step thicker than the PS. The rotors and pads were replaced just before I bought the truck. They reused the bearings, rear dust seal, and left the old grease in there. Everything was hammered caveman style. The adjusting nut, and locking nut were Chernobyled on both PS & DS from the mechanic using a chisel to tighten the nuts. The thrust washer on the DS was heavily grooved on both sides- the cone washers were toast as well. Much of the right front end noise clunking I was having especially on downshifts was related to loose bearing preload. I think this accelerated the wear on the spindle and related components.
Test drive (hwy) for 15 miles- temps on the hubs were around 120degrees DS 125 PS. Drive another 15 miles checked again, 125 DS and 130 PS. I dont have a reference for what the temps ought to be, but they should comedown as the bearings wear in. It drives smooth- no vibes.
Really thankful for the wisdom and experience shared here on Mud. Great community, it's given me much more confidence in my wrenching skills. Thanks!
Did some maintenance packing my bearings. Found a nice :rolleyes: surprise. Left by a Lexus dealer no less.
Notice the marks on the locking nut? Yes, the hacks at the Lexus dealer, who replaced my CV boots 40k miles ago didn't have the proper tools. Taking off the nut is one thing, but the chisel marks also suggest they resorted to this method to set torque on the nut too. So of course, before I even ripped into it, I know the pre-load must be suspect.
After tearing it down, it's obvious there was too little preload. The nice groove on the claw washer confirms it. Fortunately, no undue wear to the bearings or anything else. Buttoned her up with 20 ft lbs pre-load, new washer, nuts, and seals.
Set for another 60k miles.
Are you saying 20 ft-lbf torque on adjusting nut?
Look at post #16 and you'll see max breakaway preload is 15 lb. Bearing should be serviced every 30K miles. What was your final snap ring gap?
Sorry, meant 20 ft-lbf on the spindle nut. While I generally am very on top of all preventative maintenance items, I also will tailor some intervals based on my usage. There's anecdotal evidence what many go 100k++ without ever seeing a bearing service, yet they come out just fine. So 60k it is for me.
Keep in mind; Bearings loosen as they age. Loose bearings create chatter, grooving claw washer and back side of spindle which can/will cause the snap ring gap too increase.
This chatter along with wide snap ring gap creates a sawing action on hub flange & axle teeth. Loose bearing are the leading cause of N to D clunk, which remedy is to replace each hub flange & front drive shaft.
Wondering also if spindle wear contributes to requiring higher adjusting nut torque? Even with new bearings my adjusting nut torque was 25ft lbs to get a consistent 13lb f breakaway preload on the PS, and 30ft lbs on the DS to 13lb f.
Good question.
I don't disagree at all. There's a technical way to do these things and a practical way. The design of the front bearings are a very robust and forgiving time tested design. While there's always a better way, the fact is that there's a relatively wide range of acceptable clearances and pre-loads. So long as it's not incredibly lose or tight, or grease is contaminated and dry. The bearings, when dynamically loaded by the wheel, are waaay higher than the relative pre-tensions we are putting on them. So shoot for a ball-park. Just don't run them too lose!
  • Like
Reactions: uHu
I rebooted both my cv's and in the process replaced both inner and outer hub bearings loc washers etc. After reading through this I question if I packed enough grease, I packed the bearings using the palm method. Greased the spindle liberally by hand including the copper inner seals. There is a cavity in the hub between the inner and outer bearings which I cleaned out a lot of old dirty grease. Was that cavity suppose to be refilled with fresh grease?
I think it's a good practice to pack that center cavity area with grease- to help cool the hub.
Just an observation: I believe a thin layer of grease vs heaps on the spindle helps deliver more accurate preload torque setting.
Thanks for the feedback, I wonder if the Slee Bushing grease tool fills that cavity up, anyone?
Negative- slee tool forces grease inside the spindle. You need to pull the rotor off if you want to add grease to the cavity inside the rotor/hub.
Got it, thanks again!
Digging up this thread, getting ready to tackle my front rotors and i think my bearings are shot, i can move the wheel and there's a lot of play. Will repacking help or do i need to replace the bearings. Also, been reading about the snap ring gap, what is the significance of that? I've seen so many do it without caring for the gap, they just put it on.
These bearings are incredible tough, and yours may or may not be serviceable. Inspections after removing & cleaning is only way to know. But if they've been running so lose that you can wobble wheel, well, just go ahead and replace wheel bearings & races. Running that loose is hard on spindle (Steering knuckle) this is your bigger concern.
Two keys to a good bearing job: properly set breakaway pre-load of wheel bearings (tight), and narrow (tight) gap on snap ring.
Snap ring hold axle tight in steering knuckle as it passes through spindle up against the axle hub flange on outboard side, against axle brass bushing on inboard side.
Wide gap allows snap ring to pounds on groove of axle and face of flange damaging both. It also allows axle to move in and out of flange acting like a saw, sawing on teeth of axle and teeth of axle hub flange. Also the axle moving in and out, pounds on axle brass bushing further increasing gap. Axle (front drive shaft) are pricey so protect by setting gap.
Always check snap ring gap (FSM: 0.20mm or less). This is something rarely done by a corner discount shop's. They just don't read the FSM or know it will cause damage bringing customer back for more expensive repairs in the future.
Thank you, i've been searching for bearing threads and you've chimed in a lot, you seem to be the go to guy for bearings knowledge! I just ordered the 54mm socket so i can take my hub apart and see, i think this vehicle has had the axles replaced, so that's why it's possible maybe the tech who did it, didn't have the correct preload for the axle nut so it's loosened over time. I'll open it up this weekend and have a look.
Thank you all for your advice and discussion on this thread, it was very helpful to me as it’s my first time doing any work on my cruiser.
I got the kit from @cruiseroutfit :
inner grease seal
inner bearing & race
outer bearing & race
claw washer
lock washer
flange gasket
Also got the snap ring kit
(And a spring gauge and a 54mm socket)
And more new Toyota parts:
cotter pins
drive shaft
hub flange
dust cover gasket
adjusting nut
lock nuts
cone washers
grease caps
I removed, cleaned, overhauled existing knuckle w/ spindle bearing and bushing, steering knuckle arm, dust cover, and all reused hardware.
I cleaned and treated lower arm and knuckle and steering knuckle arm with POR15 regimen, mostly for aesthetics.
Some thoughts:
- I disconnected ABS sensor wires in engine bay and unscrewed and disconnected all the way down. The ps sensor had already been torn by the dealer and I didn’t want to risk destroying them thryong to get them out of the knuckles.
- I got the Slee spindle greasing tool but didn’t use it, I just slobbered grease all over and through the spindle bearings with my fingers while it was all apart.
- I followed @2001LC advice and greased all bare metal and all contacting parts.
- the bolt ends of my tie rod ends we’re crushed so badly (from an arm puller I suppose) that the factory cotter pins would not fit through the hole, I had to downsize. Same problem with lower arm connection but not as bad.
- I had to extra clean, recut, and grease threads of ps tre connection in order to get the nut to spin on without turning the ball, this took a long time and many tries. Because of this I had to make my best guess on the torque.
- I put lock nut and adjusting nut on with flat side in and big side out as noted by @2001LC (he observed original ones from the factory this way).
- I used pink Mobil1 synthetic everywhere.
- freezing the races and heating the hub did not help my install. I may not have had a hot enough lamp for the hub. Instead I used the old race for the outer and a drift for the inner. A hardwood dowel would have been better because I had to be real careful to keep the brass bits from the drift out of the hub.
- I wish I had ordered an extra set of dust cover gaskets to put between the knuckle and dust cover as per @2001LC suggestion. I will do this next time. Instead I cleaned it up real good and greased it. My knuckles were pretty ugly in here.
- With all new parts my snap ring gap ended up to be 2.2mm on left and 1.8mm on right. Tight fit with absolutely no tolerance on either. Not sure why they’re different.
- I used a wooden mallet to fit the new grease caps to the new greased drive shaft ends.
Finally, my process for preload was this (mostly borrowed from @abuck99 ):
1. Tighten adjusting nut to 43 ft-lbs
2. Spin hub in drive direction a few times
3. Retorque to 43 ft-lbs
4. Repeat until wrench clicks immediately a couple times in a row
*I THINK STEP 4 IS IMPORTANT*
5. Loosen adjusting nut until finger tight
6. Tighten adjusting nut to 25 ft-lbs
7. Check perpendicular preload tension on spring gauge
8. Spin hub a few times in direction of forward travel and check tension again
9. Repeat until I get a few consistent readings in a row
10. It’s low, so add a couple more ft-lbs to adjusting nut
11. Recheck spring gauge tension
12. Repeat until spring reads 9.5 lbf then continue (repeat) but proceed with more caution. Add torque to nut in smaller increments and once torqued, spin hub a few times and retorque until the wrench gives an immediate click. *AGAIN, I THINK THAT PART IS IMPORTANT*
13. I didn’t think it was right to exceed the original 43 ft-lb seating torque on the adjusting nut so I stopped there on the driver side. The spring gauge was reading 12 lbf. Kurt recommends heading for the top of the preload range (9.5 - 15.0 lbf) with new bearings and parts, but this was as close as I felt comfortable going. On the passenger side I got to 13 lbf preload with only 37 ft-lbs on the nut. I stopped there, knowing it would tighten once the lock it was on.
14. Slide on lock washer but don’t bend it yet
15. Install lock but and torque to 47 ft-lb.
16. Spin hub a few times and retorque
17. Repeat until consistent tight torque
18. Spin hub a few more times
19. Recheck preload
20. Repeat (spin and check spring tension) until reading is consistent. This final reading gave me a 14lbf preload on both sides. I was very happy with this.
21. Bend lockwasher tabs
I did the driver side first then repeated it after doing the passenger side with better results (those posted above). I didn’t do steps 4 and 12 the first time. I think that caused my torque readings to be off (nut was not actually getting as tight as my wrench thought it was) so I ended up with higher adjusting nut torques relative to the consequent preload. Extra spins and more care seating the nut each time I retorque it seemed to get me better results.
The most difficult parts of this process for me were getting my tie rod ends out and back in because the ball joints and taper spun pretty freely but the threaded end was corroded and a tight fit with the nut.
I hope this post helps someone else in future, THANK YOU again to all who posted before me.
