I' have replaced the oil seal, but only if rubber of seal is damaged or metal is to far gone (rusted). FSM states none reusable but at (IIRC) ~$50 its pricy for secondary seal. As you can see I put marin grease all over it front and back and same with gasket, additional I grease cavity lightly to protect from rusting. I just make sure the weep hole is open so water can escape the wheel sensor area.01,
Have you replaced this seal yet? Mine seemed to have lost its shape a bit in a few areas, and the seal material itself was somewhat stiff- it tends harden up with age, gets loose and doesn't do a good job at sealing out the dust and wet.
Also is there a consensus on wheel bearing grease for the Timken bearings? You seemed to have been studying bearing life, under various conditions figured you might have a go-to suggestion. There are so many opinions, options, misinformation its kind of hard to narrow to a choice.
Synthetic- Mobil 1, Valvoline Synguard, Timken Performance Race Grease
Moly-fortified: Valvoline Durablend or Synguard
Non-moly-Non Synthetic: Timken Wheel bearing grease, Lucas Green
Before I repack bearings I use some NAPA degreasing solvent, high pressure water, then high pressure air and pack with grease before any rust can start.
I use Mobil 1 synthetic wheel bearing grease, in fact for all lubes and oils. Why because it good stuff and is readily available for greases, ATF, gear lube & oil making life simple. Any grease will do provide it states "for wheel bearing" which is for high speed. EP greases should not be used, nor moly greases. EP is low speed extreme pressure and moly retains heat. I fill cavity of hub with grease just enough so some grease can force its way into bearings by centrifugal force, but do not over fill or it will retain addition heat.
