Thanks!
We are quite proud of our axle & bearing kits and they come only with the highest quality bearings, seals and gaskets:
FAWB9807T
FAWB9807KIT
Just sent you and order request via email! :tup:
Thanks!
FAWB9807T
FAWB9807KIT
Is this the correct kit for an 06 100 series? IFS.
forum.ih8mud.com
I would think it might be the difference between replacing one caliper instead of replacing as a set.Great info here, thank for providing the detailed info. It was a little overwhelming at first but I had some time to read it carefully and it really helps.
I have a question after helping my friend do his brake job - he replaced both brake pads and rotors, and he found one caliper was seized so he replaced just that one. Putting it all back together, got 12 lbs on the preload, and everything seemed fine. I was only there for the passenger side but he did the driver’s side using the same technique for preload but he didn’t use the fish scale on that side, just on the passenger side.
The issue before and after is that at 55 or 65 mph when he brakes, he gets that shaking you sometimes feel when rotors are warped, but these are brand new. Any ideas what could be causing this? We didn’t check the gap on the snap ring and it seemed a little malleable, so I’ve sent him this thread so he can check the gap. Could that small of a thing cause the shimmy shake only when braking?
