- Thread starter
- #221
At this point, the FSM tells you that you need a special assembly tool. There is not a picture of the tool in the FSM, however I can tell you with reasonable confdence what I guess this tool looks like. It looks like a microscopically thinner counter gear shaft that is short enough to fit between the machined surfaces in the case. It keeps everything in place while you fuss about in there and try to align everything.
Anyway, you don't need it, but you will spend a little extra time fiddling around with things to get it all aligned.
4. Use grease to "glue" the thrust washers to the counter gear. Pay attention to what washers go where. The case is keyed to accept the thrust washer with a particular alignment. Make sure you take note of how it will fit together before giving yourself a headache.
Take your assembled counter gear in the transmission. The small end goes into the top opening first, aim it at the output shaft hole. Drop the big end in, then get it all squared up to drop into its place. Make sure the thrust washers stay in place and align with the key-way in the case.
Do not make my first big mistake and install the counter gear shaft yet! Instead, just slide a really long skinny screwdriver through the location that the shaft should be, to keep the counter gear and washers relatively aligned while you install the input shaft.
5. Gather the pieces for the input shaft. There is an input shaft, a big ball bearing, a snap ring, some rollers, and another snap ring.
The bearing has a big snap ring. Mine came installed in the bearing. I left it on.
The input shaft has a small snap ring installed to retain the rollers. I did not have to remove this snap ring. Just use a small screwdriver to pop the first roller out and the rest will fall free.
Install the big bearing onto the input shaft. If you have a shop press and the special service tool, more power to you. If you are a redneck in a barn, you need a block of wood, a BFH, and a specially cut piece of schedule 40 pipe that you have named "bearing installer SST". Make sure the pipe clears the splines of the input shaft, but only contacts the inner race of the ball bearing.
Place the wood on the ground. Place the input shaft on the wood pointing up. Slide your new bearing down (double check the direction you orient the snap ring). Slide your bearing installer SST over. Apply BFH appropriately.
Note: I tap the bearing on for the first millimeter or so very gently, so I can ensure that it is square on the shaft. After you have it started and square, you may apply your BFH more liberally. AT NO POINT should you be hitting this assembly extremely hard. Just enough force to make the bearing progress toward its seat.
Now that the big ball bearing is seated, you can install the final set of rollers for this transmission build! No separating into piles, just use grease to keep them in place. I did not remove the retaining snap ring for these rollers. This means that the last one is going to be a little stubborn when you try to snap it in like a puzzle piece. Use gentle, but firm pressure and it will pop into place.
Now, install the input shaft. If you need to remove your screwdriver from the counter shaft in order to get the gears past each other, then do it. Just be careful not to allow all your thrust washers to fall out of place. If the thrust washers fall out of place, you may have to remove everything just to get it all back together again with correct alignment. Ask me how I know.
6. Now you can pull the counter gear into place and slide the counter gear shaft through. Make sure the smooth end goes in first. Also, make sure the slot for the wooruff key is aligned appropriately with the case. Sorry, no pictures for this step.
