- Thread starter
- #261
Install the pressure plate by starting all 6 bolts before tightening any of them. Double check that the slighment tool slides in and out easily before tightening the pressure plate, also. You have to spin the crank in order to install all the bolts, then spin it again to tighten them.
After getting the clutch installed, I went ahead and installed the motor mounts and hung the engine on the frame.
I removed the old throw out bearing from its carrier using a drift and hammer.
I installed the new throw out bearing using a bearing installer. The installer must only contact the inner race and no other part of the bearing to guarantee no damage.
Then I stabbed the transmission. I stuck the transfer in 4 High and the transmission in 3rd so I could spin the front driveshaft flange, which spun the input shaft while I aligned the transmission with the clutch disk. Make sure everything slides together before tightening those bolts down so you don't damage the pilot bearing. Take note that the shift fork and throw out bearing are in place in the bell housing before the transmission goes in.
I spent a little time after this cleaning and painting a few bits and pieces. I left with it looking this way, mostly.
Questions:
1. I installed the front driveshaft with the slip joint near the transfer case end. Is this correct?
2. The valve cover vents were aimed toward the back (firewall). Is this correct?
Questions:
