Barn Rebuild: The family heirloom
Pictures of the pistons after rinsing in the parts washer.
I will be tearing down the oil pump and measuring clearances soon.
A cheap 2.5-3 gallon unit that recirculates organic solvent. I don't remember the brand, but I got it at a garage sale for $8. It has diesel in it. Pretty sure it is the washer you would buy from HF or comparable store.
By the way, I measured the clearances in my oil pump and all are great. The pump looks very good inside. Now, I have to make a new gasket for it, since the old gasket was shredded upon dis-assembly. Normally, I would seal with silicon, but the gasket has an affect on the operations of the pump. No gasket with only a thin coat of silicon would cause the gears to grind into the cover.
Does anyone know the gasket thickness I need? I can't find a part# for the gasket, so I figured it would be reasonable to cut one from a sheet. I would hate to have the wrong thickness and have resulting inoperable oil pump on my cruiser.
I can get 1/64, 1/32, or 3/64" sheet cheaply from the big box auto chain. The gasket that came out was reasonably thin material.
Edit #2: I can figure out the thickness I need with a feeler gauge and a straight edge. There is a clearance spec in the FSM for the gear-to-cover end play.
I went to the trouble of searching and uploading FSM info before reading Edit#2.
So I'll dump the results here anyway in case it's useful to others Heirloom:
I reckon that engine's going to turn out great with your attention to detail. :)
:beer:
nice thread so far!! i know you had alot of machine work done, but you didnt mention if you got your rotating assembly balanced or not, toyota was super sloppy with there balancing, and doing so helps these motors greatly
H,
Do you have a cost breakdown on the engine rebuild steps? Novice here, not sure of all the steps, optional or required, and which can be done by a knuckle dragger like myself, and what is required by a pro. Any summary of those steps, no matter how short, would be educational.
I rebuilt the transfer case today. I could give a big writeup, but I used a combination of the FSM and Coolerman's site for step-by-step guidance, so I will just link to coolerman's site and those of you that are interested can look up directions.
http://www.globalsoftware-inc.com/coolerman/fj40/34A.htm
I painted all the covers and cases, I replaced all the bearings and seals, and I generally had to do everything twice to make sure all the pieces were installed correctly because I am mostly just a dumb hick.
By the way, I am aware that painting the aluminum parts is not "factory". It's my party and I can paint what I want to!
Jealous you did it in a day. Taken me 3 weeks, an hour or two at a time.
Any issues when setting preload?
Other than having to disassemble/reassemble because i forgot one of the pieces the first time, no preload issues. I reused the shim that was installed under the speedo housing and everything went together the way it came apart. It all turns smoothly with the appropriate amount of force.
One note on transfer case assembly: there is a casting plug that installs behind the idler shaft. It looks like a freeze plug, only smaller. Install that VERY last. I installed it first, which made aligning the thrust plates on that side of the idler shaft a chore. I got it, eventually.
H,
Off the top of my head, lets see how much I have wasted on this.
Head rebuild:
New bronze guides, hardened seats, grind intake valves, new exhaust valves, all new springs, freeze plugs, seals, mill sealing surfaces after cleaning it. $600 ish. The head builder has the best reputation for quality, so I let him do all assembly.
Block:
Clean, hone, new freeze plugs, install cam bearings, clean and polish crank and cam, measure everything to verify factory tolerances. $200.
Bearings, gasket set. $300 ish.
Rings (American made) $93.
I'm sure there are many items missing from this list, but we have to insulate my wife from the total price, just in case she decides to read over my shoulder.
Just read the whole thread and was reliving the experience of working on my 1971. Excellent work so far... Glad you can get your wife to help you, mine won't even come into the garage!
When you get to the wiring part of your restoration let me know if you need any parts or advice to fix the old harness, or if you want to replace it with a new one. Good luck with the rest of the build! :wrench:
Thanks for the kind words, everyone. Coolerman, thanks for the offer and thank you very much for the transfer case assembly guide on your site.
I made my gasket today for the oil pump. The clearances were perfect for a 1/64" gasket. Now, I have 3 feet (less a couple square inches) roll of gasket material for the princely sum of $3.50.
This is a rough cut. I cleaned up the edges a bit after I took this pic. Tip: perfect bolt holes can be made in your gaskets by sacrificing a socket. I used a 1/4 drive 1/4 socket and turned the tip against a grinder to make a sharp hole punch. Perfect round bolt holes! I have bunches of Chinese sockets in triplicate, so I could afford to ruin one.
I also painted the transmission case. De-gunked with diesel. De-dieseled with simple green. De-greened with denatured alcohol and compressed air. I primed with rattle can rust reformer (the phosphoric acid preps the metal for adhesion) and painted to match the transfer case and engine block.
I found that my used 45 calibre and 9 mm shells from my handgun make perfect hole punchers for Toyota gaskets. A 22 calibre also makes good holes for oil passages.
And I thought I was the only one who used this method lol
Awesome idea. If I had as many casings laying around as I do crappy sockets, I may have gone this route.
This is unfortunate: I can't rebuild my trans for over a week! I leave for vacation tomorrow. The paint needs 24 hours to cure before I start tumbling that case around on a workbench. At least I know the hardener will have done its job by the time I return.
Another tip: the less toxic paint thinner for oil based paint made by Kleen Strip congeals after a couple years on the shelf. I am going to keep it simple and buy old fashioned thinner from here out.
Why use spent casings, just shoot 'em with new ones? Same size holes, much more fun!
Sure, but then you can only make holes in the day time without pissing off the neighbours....unless you're in Detroit of course and then who'd notice a few more gunshots here or there?
I'm back from vacation, which means that my real vacation can resume. Today, I drove over to the barn to take care of that nagging transmission rebuild.
Since Coolerman does not have a wonderful transmission rebuild write-up, my initial plan was to make one. I charged my camera and packed a cooler full of cold water, then I set out for the barn. Truth be told, if I had documented the build in real time, it would have been a lesson in how not to rebuild the 3 speed transmission. I had to disassemble a few parts a few times, because I forgot to install parts or because I misread the FSM and installed parts incorrectly.
This means that I have pictures from the first half of the build, but I got to a point where I had to keep my hands too dirty for the camera and focus all my efforts to assembling the trans correctly. I will give you guys what I have and we'll see how it turns out.
I disassembled the transmission according to the FSM. I did not take any pictures at all. This will only be a record of the assembly.
1. Before touching any parts, Print the exploded diagram out and put it on the wall above your work table. This is as close to surgery as you can do on a vehicle, so make sure you have a clean enough work environment. Sweep off those metal shavings from the band saw and grinder before spreading out your parts.
2. Start by assembling the reverse idler gear. It has two rows of loose needle rollers that need to be placed inside the gear. A small spacer/washer goes between the two rows. I assembled with non-moly axle grease to keep all the little rollers in place. The FSM tells you that you need 56 rollers.
TIP: separate your rollers into groups of 28. This helps you keep track of how many rollers to put in each side of the gear.
The last roller for each row should almost feel like a piece of a puzzle snapping in place.
Place the thrust washers on either side of the gear. I used grease to hold them in place. Slide it into place in the transmission case. There is such a thing as backwards, so make sure the ramped side of the gear teeth are facing into the transmission cavity.
Insert the new reverse idler gear shaft that came in the rebuild kit. Tapered end goes in first. Make sure that the groove for the woodruff key is going to fit in place after everything is seated.
3. Get out the counter gear, 96 new rollers, new counter gear shaft, 4 bearing spacer washers, one spacer sleeve, 1 woodruff key, and all thrust washers that you took out. In my case there were 3 thrust washers.
Separate the 96 rollers into 4 small bowls of 24 each so you can keep up with what goes where.
Use plenty of grease to hold everything in place, and install 1 row of 24 rollers into one end of the counter gear. Inspect carefully to make sure everything looks appropriate, then use one bearing spacer/washer to slide the bearings to the appropriate depth in the counter gear. Use a lot of grease to install the second row of bearings, then the second bearing spacer/washer.
Carefully turn the counter gear over so that the first 48 bearing rollers do not fall out. At this point you are glad that you used the stickiest grease you could find.
Carefully slide the spacer tube into the counter gear and begin installing the other two rows of rollers in a similar fashion to the first side.
Note: unlike the reverse idler gear, the spacer/washer is between the rollers and the thrust washer.
