Any tips on getting this washer back in place? (1 Viewer)
Australia
The washer that's pressed into the alternator mount has popped out (Wether it's supposed to to that or not idk) and I can't get it back in to refit the alternator anyone got any tips on how to do it or is there a tool that will do it.
Use a C-clamp
FWIW, it's a sleeve, not a washer.
Measure the bracket bolted to the engine that the alt mounts to.
Make sure that piece sticking out is not meant to be sticking out.
That’s a brass bushing I would guess that’s why you can’t remove the washer🤷‍♂️
^^^ This
If you can't maneuver a C-clamp in there a nut & bolt and a big washer should pull the bushing in
That's a floating bushing. It's meant to move in and out to clamp the alternator tight regardless of discrepancies is casting variations.
Use a little penetrating oil and free it up tapping or clamping. All that I've encountered were steel so you can abuse it.
