Orangefj45 = da man.
I cannot find the rear main cap torque spec for the 3FE. Is it the same 85 ft./lbs. that the 2f calls for?
This man speaks the truth.
My old t case has more than .017" and less than .021" of thrust clearance on the idler gear before dis-assembly. I haven't spent alot of time looking, but a half hour of searching hasn't got me that spec. Any help there would be great! Thanks.
i'd use the flywheel bolts, the flex plate bolts are a hair shorter. make sure you put some sealant on the bolts since they screw into a "live passage".
if you need more help or parts, you have my #......
also, i did a write-up on here about this swap. pretty detailed.
hth
georg @ valley hybrids
Georg,
I just found that thread and I think that's been the best visualization of what I'm planning on doing. This is kind of a minor question, but what did the interior of the 62 end up like with the H42 installed.
Thanks!
LAMBCRUSHER said:Can you post a link or thread title. I could not find this and I looked for a while. TIA
trans crossmember is in. will post pics of the build later. Now I have to find a gear to replace my idler or maybe have the old gear bored and sleeved???
