middlecalf
Lockers on fire roads? I’m not even in 4wd on most of the fire roads I’ve been on.
Some of the benefits of my day job!
Needs to be more centered if you can.. What is your back lash? Did you happen to measure before you took it apart or run a pattern?
@matzell
Here is attempt #3.
I actually removed a 10 thousands shim earlier, I just added 5 thou back to that.
Here's the drive pattern
View attachment 2315808View attachment 2315809
Soo jealous. Not much fly fishing here in central Illinois. Folks look at me weird when I break my Sage for bass fishing.
So I spent the dollars on my 40 ($2100 installed while my rear end was gone through) and put and Auburn LSD in the rear. I’m extremely happy with it. No popping, snapping, or crunching when turning tight and my tires slip maybe 50% of a rotation before it engages. If you can, I 100% recommend it. Also, open up that rod holder, I am a curious creature. And have you considered going to a Tenkara style fly fishing to circumvent the storage problem? I ordered a rod to give it a go.
Quick question and please forgive me if you already listed the specs in your postings. I am starting preparations for primer and paint and yours looks pretty good. Can you tell me the type of gun you used and how many CFM your air compressor pumped out?
Don't admire my paint job, it's about as amateur as it gets!
I used about a half dozen harbor freight paimt guns, after the first couple I just quit cleaning them. Toss em in the can and open a new one.
The compressor is a different story, it's an Ingersoll Rand 80 gallon 5 hp unit, way more flow than necessary, but I bought it as a long term tool.
