s***, late to the party as usual. Happy Bday JT....
Too much work!
Too much work!
Trapper50cal said:Well,
Chunk is a Pagosa cruiser, now.
Unpacked the moving truck today.
Ahhh, it's like 45-50 minutes (in a 60) not bad. I just can't get hammered and try to drive back...[/QUOTE
I hear ya on that one. We'll bring the's and they can drive our sorry butts back.. HA!
J
Here's my theory:
The smog pump/smog system was causing a crankcase pressure issue that was allowing excess oil to travel (either in vapor or liquid form) from the PCV line on the top of the valve cover into the air cleaner assembly that was then leaking out the bottom of the air cleaner assembly all over the cylinder head directly below it.
Now that the smog pump is no longer pushing air, the crankcase pressure has gone down an the PCV line isn't carrying oil into the air cleaner assembly to then exit through that vent.
OR
The lower crankcase pressure is disallowing the engine's ability to push oil through the side cover gasket....or both.
Seem possible or am I just dreaming this sh!t up?
The smog pump pushes air to the exhaust side of the equation (air injection ports or exhaust pipe) or to the air cleaner so I can't imagine taking that out of play having any effect on crankcase pressure. Maybe you still have a PCV valve issue routing excessive oil to your air cleaner, but without the air pump pushing air to the air cleaner it's not 'slopping' around enough to leak out of the air cleaner?
Butt
I'd also check compression numbers and look to see how much blow by your getting for future reference.
That's my .02 on this occurrence... Good Luck Trap..
J
JT, if you want my compression tester or leak down tester let me know. Myself or M will be in Pagosa on Thurs.
Forgive my ignorance, but wouldn't blow-by be evident in the way of blue smoke from the exhaust?
I would like to know my compression numbers though, as the engine has 214K on it...
Trap, I was not implying you have a blowby issue currently. Just a general statement to see where you stand for future knowledge, so you can gauge it, if you did.
Yes, blue smoke is indicative of burning oil. Rings are allowing oil to slip by. Constant blue smoke would be bad rings... A little smoke at start up and then dissipates in a short time.. valve guides..
J
