PO installed some kind of hose (not OEM) and it actually looks like it could collapse with suction. Thoughts on what to use as replacement of just quit being a cheap a** and buy new?
-thanks
-thanks
I acquired an EMS Powered pipe when I got my exhaust. Not sure if they can be sourced now or not.
did you have to photoshop in the sparkle?I got all the tubing from advanced, A 45 deg and straight, Used the OEM coupler on the air filt MAF end. i also had to raise the two front mounting legs on the air filter housing to line up the housing to the intake. I just used some Energy suspension sway bar link bushings (red) and longer bolts.
View attachment 938824View attachment 938825
It is stupid expensive for what it is. I'll post up my pictures of my homemade one when I get homeJust get the OEM Toyota part, makes no sense not to.
did you have to photoshop in the sparkle?Looks nice
Why would you put a rigid piece piece of pipe between the top of the engine and the air cleaner bolted to the fender? The engine moves under acceleration and engine braking, the rigid pipe should break the mounts off the air cleaner or something else will give.
