Over the Winter, the 30A breaker blew. Reset and it blew one more time. Disassembled blower motor and cleaned windings and such...no further issues. Last Summer..aka October here in Cali...the AC worked fine.
Now, went to check AC system as Summer's on us...the AC button lights up but the AC idle up doesn't engage nor does the compressor clutch. 12V is leaving on the Yellow wire from the AC switch. I can jumper the connector on the A/C amplifier Yellow to Black/White and the clutch will engage when AC button is pressed. Makes sense as it's just a straight shot at that point. I'm not sure of coolant levels but the AC idle up should still engage even if that's the case right?
The blower motor works fine on each of the 4 speed settings. I'm guessing it's the AC amplifier but would like to hear suggestions? Other troubleshooting steps?
