That's your axle breather, nothing to do with the brake lines.
the pedal goes to the floor the first press, then part way on the second before firming up. What's that about?
I do have a booster. That was what started me down this road in the first place. It was leaking air. Replaced it and as I was putting it on, I realized my master was shot so got a new one of those. Bench bled it, installed it and started getting the wierd soft then hard pedal stuff. Found a bad cylinder. Replaced them all. Testing it, blew a soft hose. Replaced them all. Now adjusting and tweaking the cylinders. Thought I was good this morning. Long drive, pedal got steadily harder. Came home, let it cool, got in, pedal to the floor first 2 pumps, then felt good. I re bleed. Feels good but still seems like something is wrong.Do you have a booster or are they manual?
*Just found where you mentioned replacing the booster without disconnecting the master.*
Something hay-wire here![]()
I got a bench bleed kit so I think can do it while installed.AIR in the system! BLEED again
I believe that's a proportioning valve for your brakes, not a breather for axle! It has brake lines feeding in from both sides. That's where your air leak isI may have spoken too soon. Took a nice cruise and the pedal got steadily stiffer and had less play until it was hard all the way at the top. I could tell there was a little increased rub on the shoes so I opened up the cylinders a little and that helped some. I'm guessing I'm still in the adjustment phase however I noticed this on the back T fitting. I don't see anything about it in the Haynes Manual or the FSM pdf I have...so what is this and why is it leaking? Feels like a pressure relief valve or something. I'm guessing this isn't a good thing. Also seems like the fluid leak would cause a softer pedal...not sure why it would get harder as it drove. Again I have a brand new booster, brand new master, brand new soft lines and no leaks on the hard lines. I was gonna go back and bleed again to see if there's any air in the lines again. Any thgouts are helpful.
The pic below is a little bit of an optical illusion. There is no line coming out of the top of that leaking valve/fitting. Just the hanger for the sway bar View attachment 2649099
I believe that's a proportioning valve for your brakes, not a breather for axle! It has brake lines feeding in from both sides. That's where your air leak is![]()
New master with no relief valve.
I looked up axel breathers and they do match whats in the pic, although it's clearly running through that T fitting for the 2 rear hard lines. I don't know if that's normal or not.
