I have a 1971 FJ40 Drum brakes all new cylinders, shoes and drums. It also has new brake booster and master cylinder. It was fine for the first 20 miles then I drove it to get inspected it passed but they said my brake pedal was really hard with vey little play. When I got in the car to drive home they were right the pedal had lost all the play. I stopped to get gas after about 10 miles and when I went to pull out my front brakes were locked almost solid. I had to wait about 15 minutes for them to release so I could limp home. I have adjusted the rod between the booster and the master several times but they keep locking up if I drive more than a few miles. Hitting the brake does not seem to have anything to do with it, is seems to be based on how long the drive is. I replaced the rear brake lines and have ordered new flex lines to replace the original rubber ones up front. If this does not work any suggestions? and how sensitive is the adjustment of the rod between the booster and the master? can a one turn either way to much cause this?
