BajaCruiser94
Current Form:
1997 FZJ80 - 40th Anniversary Edition
190K Miles
Head Rebuilt and Gasket done 500 miles ago with OEM parts.
Magnuson Supercharger Installed during head rebuild
Orange Hub Fan Clutch sourced thru LandTalk
Running Stock Non-Ringed Fan
Thermostat done 1 year, 1000 miles ago.
Radiator serviced 50 miles ago.
ProComp Aux Fan Installed
Original Shroud, with lower part damaged.
ARB Bumper, 305 BF MT's, Stock Gearing.
Some extra datapoints:
- Monitor tool; OBD2 ELM Bluetooth Adapter with DashCMD app in ipod.
- Before supercharger, no high coolant temperatures.
- Supercharger, stock fan clutch + 20K oil + Ringed Fan + cool weather, no high coolant temperatures.
- No difference observed by running the Aux Fan (expected).
- Orange Fan Clutch is a monster, huge amount of air is felt, audible roar is amazing.
- Max temperature observed has been 219, no AC cutoff yet
- AC Performance is excellent, even at 219.
- Baja Heat Max is around 125*; very dry heat; havent reached the max so far this year
- IAT are between 135 and 150*
- I can manage to lower temperatures by increasing idle speed while in neutral to 2000-2500 rpm's.
- Opening the hood and increasing idle reduces temperatures faster.
- Using boost on the streets significantly increases temps.
- Lower fan shroud got damaged by the ringed fan due to worn out engine mounts; mounts were replaced and shroud will be replaced next week.
- No catalytic converters.
- No coolant leaks.
Hard Data:
SC + RingedFan + Stock Clutch w/20K Fluid:
80C Weather - OffRoad Trails - 196-201.
90C Weather - Highway 196-207; Max was achieved using boost on a long incline; cooled down after.
Stop an Go traffic at town 205-215.
100+ Weather - No Data, didn't dare to drive it.
SC + StockFan + LandTalk Orange Hub Clutch
90+ Weather - Highway - 196-199
Stop and Go traffic at town 199-203
100+ Weather - Highway - 203-205; no inclines.
- Stop and Go traffic at town 208-219 (Max was reached at a stoplight)
While doing some tests on my driveway after arriving home from a small drive at night wih 90ish weather; temps were 199; then every two minutes or so it will creep up 2*; after 20 or so minutes idling with AC on, temperature reached 217, then I opened the hood, then temperatures came down to 215; increased the idle and I could get them down to 199 again.
So, Im not overheating yet, but Im in the limit; and I feel I shouldn't be; I've read guys in Phoenix with similar weather are always running below 200; so Im clearly missing something; and I dont want to start throwing money (more) at it randomly
The Radiator shop mentioned my rad didn't have significant sludge in it; just normal build up; no difference found before and after rad service.
Im ruling out the Clutch because its new, its sourced by LandTalk and the roar is obvious together with the AC outstanding performance.
Im achieving airflow, Im just not getting that airflow to cool the coolant, and its only on 100+ weather temps, even on the highway, I feel and observe temps not cool enough (sub 200*)
Hood vents are being installed on Monday; but I dont expect 10* difference with them.
Things that havent been replaced yet:
- Water Pump
- Radiator (Serviced already, but not replaced)
Sorry for the long post, been gathering lots data to provide a clear picture.
Thanks in advance for all your inputs.
-Emerson.
190K Miles
- No coolant leaks.
Hard Data:
- Water Pump
-Emerson.
