I have been plagued with overheating issues for half a dozen years now. The truck has always been on the higher side of comfortable. I have now done everything under the sun to try and mitigate the issue to no avail!!!!!
Today was the straw. Its currently 110º outside my house here in West Hills, CA. As you can see from the image, the truck is now at 234º. Its typical temp, when its over 100º out, is 213-217º. I really don't know where else to go with bringing the temps even into the warm range that most SC owners deal with. My truck is just too damn hot. I'm all ears guys. Here is the long and short of what I've done so far (all under 30k miles):
• Truck as327k 334k miles on it. Engine was completely and expensively rebuilt at 298k:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/
• During the rebuild the SC thermostat, all hoses, all belts, water pump were replaced with all OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-8#post-7367876
• or so I thought. Tstat was Beck Arnley, replaced with OEM:
https://forum.ih8mud.com/threads/im...erheating-despite-best-efforts.813023/page-43
• In April, before my big Yellowstone trip, I replaced my s***ty radiator with a Ron Davis all aluminum radiator:
https://forum.ih8mud.com/threads/ne...ing-into-stupidity.802799/page-4#post-9227967
• Entire cooling system was flushed and then flushed again with distilled then filled with 50/50 Toyota RED and distilled:
https://forum.ih8mud.com/threads/ne...ing-into-stupidity.802799/page-3#post-9196744
• Exhaust manifolds and shields were ceramic coated:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-6#post-7347657
• Heater control valve replaced with OEM:
https://forum.ih8mud.com/threads/engine-rebuilding-options-for-s-c.553208/page-22#post-7700890
• AISIN blue hub fan clutch new from Amazon and filled with 30k CST and adjusted to 105º, fan roars on start up and roars when driving:
https://forum.ih8mud.com/threads/blue-fan-clutch-mod.102633/page-34#post-9227333
• Radiator misting system added to reduce spiking temps:
https://forum.ih8mud.com/threads/ne...ing-into-stupidity.802799/page-4#post-9226672
• Added flush hose to also allow for burping the cooling system:
https://forum.ih8mud.com/threads/ne...ing-into-stupidity.802799/page-5#post-9233838
• Louvers added to the hood:
https://forum.ih8mud.com/threads/my-newly-vented-hood-20-photos.386741/page-6#post-6768429
• Replaced fan with 3FE fan
• Replaced new OEM radiator cap for kicks
• Dumped in a bottle of Water Wetter per suggestions
• Replaced all of the missing radiator foam on both sides of the radiator:
https://forum.ih8mud.com/threads/ne...ing-into-stupidity.802799/page-5#post-9228020
• Added JDM fan years ago:
https://forum.ih8mud.com/threads/jdm-aux-fan-install-it-doesnt-get-easier.160331/
• Fresh oil change less than 5000k ago with Mobil 1 Syn:
https://forum.ih8mud.com/threads/how-to-oil-change-for-the-non-purists-to-complain-about.807853/
• Timing is set to factory 3º
• Running cooler MR2 plugs
• Catalytic converters and Y-pipe replaced with CA carb compliant FlowMasters (Feb 2014):
https://forum.ih8mud.com/threads/im...erheating-despite-best-efforts.813023/page-70
• Installed Safari Snorkel which changed my IAFº temps MAJORLY:
https://forum.ih8mud.com/threads/im...pite-best-efforts.813023/page-69#post-9578218
• Added Photoman's billet water pump pulley which is 15% smaller which makes the water pump spin faster at lower RPMS:
https://forum.ih8mud.com/threads/im...pite-best-efforts.813023/page-63#post-9362600
• Truck as
