Hello. Can't find the specs for the transmission filter torque. In Haynes all it says is transmission oil pan to 61 in lbs. No mention of the filter torque. Chiltons says "Inspect, clean or replace the transmission filter or strainer at this time, if necessary. If the filter is removed, be ready for an additional rush of fluid. For all transmissions except the A440F, tighten the bolts to 48 inch lbs. (6 Nm). On the A440F, tighten the 8mm bolts to 48 inch lbs. (6 Nm) and the 10mm bolts to 7 ft. lbs. (10 Nm)." On a 96 LC repair manual it says 84 in lbs. Does 48 in lbs sound about right?
