John Staton
Long story short, I had a bad alternator when I got the truck years ago and a mechanic switched it for an aftermarket alternator. He changed out the bracket and connector to make it work. I had ordered a brand new denso OEM alternator and finally got around to switching it out today. All went well and the truck started fine when we were all done and buttoned up. Took it for a test drive and noticed the charge light is now on. One hiccup when doing the install....the white wire was arcing when I hooked up the battery and started to smoke. I immediately disconnected the battery and covered with electrical tape and bent it so it wouldn't touch metal again. You can see how much voltage I'm getting now. I'm wondering if it is too high or what else could be wrong.
Old alternator that was doing fine. After it was installed it had to be swapped out twice. Had a lifetime guarantee but who wants to keep swapping out a s***ty part.
I bought the denzo alternator from a vendor off of mud along with the bracket and connectors to go back to OEM.
The voltage now....is it too much?? Or could I have messed something up when I arced the white wire when I initially hooked up the battery. Was maybe 5 seconds... Enough for the rubber to start to melt and smoke on that wire.
